My maxim 17'' lcd widescreen tv/monitor is playing sound ok, but isn't showing a picture. The screen just went black, and has stayed black ever since. Thanks for your time guys.
  • info20988 Jun 04, 2009
    Its maxim 11-40 17 lcd
  • Michael Masters
    Michael Masters May 11, 2010
    I need a model number and make...
  • 822 Answers
Pls check the inverter board, lamps, lamps connector. check secondary power supply budged capacitors check it.
Posted on Jun 04, 2009
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
While watching television the screen just went black. We allowed it to cool down over night and still no picture or sound. The Foxtel information does come up at the bottom of the screen, but no...
I was going to inquire if Foxtel is your cable provider but have established that already. Judging from a description of their service, you have a convertor associated with Foxtel.
See if you can call up your TV menu (for doing initial setup). If it shows up your set is probably OK with only the tuner a potential suspect and these are quite reliable in comparison to some of the other subassemblies in our sets, then I would contact your cable provider as it seems the cable box has expired.
If you have any other video source such as a camcorder with video output or a DVD or VCR, try those.
Jun 06, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
I have a new flat panel 21" monitor which I love. However, photos which I took of taller objects and some Windows games appear too wide and not tall enough. The same thing can happen on the new TV's when...
It sounds like you have the resolution set wrong. Typical monitors are setup with a 4:3 aspect ratio. With the widescreen monitors, you have to get a resolution that will support the 16:9 I purchased a dell monitor a while back that was the same way, and I just went in and made sure I had it set for the 16:9 aspect ratio.
Right click on the desktop, go to Personalize(Vista) or Options, and then system tab, and slide the bar along the resolution ruler to the correct size. Play with them a little too, to make sure it fits you best. Some of the higher resolutions will show more screen space, but will have smaller text.
Mar 15, 2009 | HP w2558hc 25.5" Widescreen LCD Monitor
Powers up, shows test menu then black screen
This sounds like a video problem with the COMPUTER.....try the monitor on another computer. Usually, if you can see the monitor test pattern the monitor is ok.
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Starlogic 20 inch widescreen monitor screen keeps going black
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
Black screen on tv but still have sound!
i used to work on the warantee's for relysis from memory that was a deffo dead un we used to swap out on that fault im pretty certain its a dead processing board . . . sadly relysis uk went bust . . . .
Jan 17, 2009 | RCA F32450 32" TV
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Bush 17" LCD TV
with your remote go into the menu and do you see that??? ok if you do go to the closed caption and see if its off. if its not then you have a backlight problem and you should seek professonal help with that. Good luck
May 11, 2006 | iiyama ProLite E430T 17 in. LCD Television
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
