Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
BEHRINGER PMH1000 POWER MIXER FAULT - TRIPS HOUSE ELECTRICS
PMH1000 TRIPS THE HOUSE RCD FOR EARTH LEAKAGE WHEN UNIT IS TURNED ON. TYPICALLY IT WILL TRIP 1 IN 3 TURN ONS, NO MATTER WHERE IT IS PLUGGED IN. I HAVEHAS TESTED THE UNIT IN OTHER HOUSES WITH SIMILAR RESULTS?
ANY SUGGESTIONS?
ANY MANUALS OR SCHEMATICS SHOWING THE PSU?
  • Behringer Master
  • 5,603 Answers
THIS MAY BE NORMAL. The starting transients can trip RCD's or GFCI's as we know them due to high frequency components that are not balanced due to capacitive coupling. IF you have the inputs connected to OTHER devices such as effects modules that also have line power to them there may be a ground loop.
ALWAYS connect any interconnected device to the same power source for equipment safety. Behringer is stingy on schematics.
You MIGHT try using a decent line filter to supply the unit. It has been a while since I repaired my 1000, but I don't recall any specific thing in the design to unbalance the current, HOWEVER the power does go through a thermal switch on the heat sink for the power transistors and the wiring CAN be dressed so that it might couple to the other internal wiring AND the safety ground. Suggest you try a small lamp in series with the safety ground (third wire) to see if you get any appreciable current there during startup. Make an adapter... DO NOT cut into your power cable to do this.
Posted on Jul 27, 2009
Bosch Classixx 1000rpm. Trips out RCD each time turned on. Am able to use other appliances in same power point. Only 3-4 years old
If the RCD is tripping then the appliance has an earth leakage fault. You should remove the plug from the power point and not use it until you get it repaired. This is a potentially dangerous fault, and the RCD is telling you it is faulty.
May 19, 2016 | Bosch Washing Machines
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
I have a 4 year old model WGP 95 pump which has been running trouble free until a few weeks ago since when it has developed a recurring earth leakage problem which seems to make no sense. When operating...
I assume the RCD is an overload protection device. I would check the pressure side of your system and be sure it is clean. It sounds like it is building up back pressure. and overloading the pump motor.
Aug 14, 2013 | Little Giant Plumbing
Xerox Phaser 8550 tripping RCD on warm up
IF the warranty is still in effect, call for service.
IF no warranty, then check the heaters for the solid inks.
Probably a bad element, or a shorted element.
Unless you are skilled with electrical meters, V-O-M type,
this could be dangerous.
DO NOT ATTEMPT to troubleshoot this with power on.
IF you can use a meter, with the power OFF,
check for continuity and resistance with multi-meter set to Ohms.
BE CAREFUL!
Electricity can KILL!
Jul 27, 2012 | Xerox Phaser® 8500, 8550, 8560, 8560MFP...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Refrigerator trips the aerth leakage in house every 45 min - 1 ho
Problem solved. The drain pipe from the frost free elements were blocked and caused a short to earth when defrosting cycle started and that caused the problem. when I opened the pipe the water drained and end of problem.
Regards
Koen Malan
Mar 27, 2009 | Daewoo Refrigerators
Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Sep 22, 2008 | AEG U3100-4 Electric Double Oven
Car Audio & Video Logo
749 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
