Question about Logitech Harmony 890 LCD Remote Control
I have a logitech 890. The remote only turns the
I have a logitech 890. The remote only turns the tv on and off but nothing else.
    Problem Solver:
  • 5 Answers
What are the other devices that you have
are you trying this in device mode or are you trying this within activities
have you checked the power settings for the other devices that you have like leave the device on all the time
have you checked if the other devices you have can be controlled in device mode
Posted on Jun 09, 2009
4 Suggested Answers
  • 101 Answers
SOURCE: I have a logitech Harmony 890 remote. The battery
To check to see if your device is controlled by a RF (radio frequency) or IR (infrared) remote:
Power the device on manually
Cover the front of the original remote that came with the device with your hand
Press any button on the remote that you know the device would respond to normally
If the device responds even when your hand is covering the front of the remote, the remote is RF and the device cannot be controlled by the Harmony remote
Another test that can be performed is using digital camera:
Using any digital camera, even one on a cell phone, camcorder or webcam, look through the screen of the camera at the front of the remote
Press a few buttons on the original remote
If you see flashes of light as illustrated, the remote is IR and the Harmony can control it. If the remote does not flash, this original remote is an RF remote and the device cannot be controlled by the Harmony remote
For comparison, try the same steps with a remote control that you know is working correctly, such as the original remote for the TV, or DVD player. You should see the IR emitters flashing when performing this test.
Posted on Feb 10, 2010
SOURCE: Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Posted on Jan 12, 2009
  • 57 Answers
SOURCE: I have a logitech 890. The remote only turns the
this remote has a help button to resolve setup issues. you should see a message on the screen ask ing if you need help. If not this function can be activated using the setup software. Try using the remote to watch TV. Then press the help button(be sure to have the remote pointed at the TV). The remote will attempt to fix itself. the screen will then ask if that fixed the problem-choose yes or no. Continue to follow the prompts until everything is the way you want it.
This should get everything working for you. I assume you did connect the remote to your computer and went through the setup software.
I use this remote and I love it. Just be sure when using it to give time for it to send commands to all the devices.
Posted on Nov 06, 2009
Display on 890 remote is faintly lit. I have a new battery and cradle, have updated remote (firm/soft)....nothing. Remote does work, but you can't see display, so you are enabling the 'force'...
Not worth repairing, contact harmony and they will give you a coupon for 50% off a new remote. The 900 replaced the 890, although I prefer the 890 the screen is a lot better on the 900.
Oct 30, 2011 | Logitech Harmony 890 LCD Remote Control
Tip
Harmony 890 Manual Download
Download Logitech Harmony 890 Remote Control Manual
Have you misplaced your Logitech Harmony 890 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Logitech Harmony 890 Universal Remote
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 890 LCD Remote Control
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
After turning on Samsung TV with Logitech 890, the tv does not right away. I hear the tv trying to turn on but it takes about 30 seconds to do so.emote
This may not be a remote control problem. try turning on the tv directly from the tv and see if it takes longer than normal to power on. Sounds like a problem with the tv.
Dec 08, 2010 | Logitech Harmony 890 LCD Remote Control
Nov 06, 2009 | Logitech Harmony 890 LCD Remote Control
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
I recommend resetting it up with your components to get rid of the two channel problem.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony MAC Software Download
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Everything But The TV
This FAQ on the Logitech website gives you detailed solutions. Please read all points!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2367
Hope that helps! Dont forget to rate this a Fixya if my solution helped you.
Cheers!
ID
Nov 06, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
198 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
