Question about Lincoln 4000 Fresh-O-Matic Rice Cooker
Lincoln Fresh o Matic Leak
I have water leaking from around the piece where the water pump is. How can I figure out if I need to replace the pump or the seal, it's not exactly easy to get it apart!
  • daveqofgad Jan 14, 2008
    elieonaiofgad and Guest,
    Thanks! I fixed it, actually. I fixed a couple of them now, actually. It wasn't that bad, actually.
No steam burst when punped?
Posted on Jan 12, 2008
Hello daveqofgad
You should ask Jacobofmanassah. He fixed many of ours. Actually I was here looking for a decent price for a new one because the steam plate in one of them just cracked.
Posted on Jan 14, 2008
When connecting the water to the city water connection it filled my fresh water tank. Is that normal?
Probable cause would be a leaking check valve in the pump.
On the RV the city water and discharge from the fresh water pump are tied together. When on city water the discharge of the pump will have city water pressure on it. If the internal check valve on the pump is leaking, water will flow through the pump backwards and into your fresh water tank.
Mar 15, 2015 | Heartland 2014 Gateway 3200RS
In 2005 chevy impala the heater only gets warm sometimes. Other times it blows cold air. I put fresh antifreeze in. And there is no water on the floor of the car
The adding adding coolant means you have a leak somewhere, and low coolant level will cause this. How often do you check the fluid levels? Check for leaking hoses, weak radiator or expansion tank cap, leak at the water pump, and leaks around the radiator.
Nov 13, 2014 | Cars & Trucks
Dodge neon oil leak near the water pump
sounds like your front main on your engine
May 21, 2013 | Cars & Trucks
Why does 2006 lincoln navigator air ride suspension lower at stop signs and lights
you have a leak use a spray bottle of cold water and dish liquid turn on key and let it pump up spray all lines and air operated parts to locate the leak. then replace parts as needed. best of luck
Nov 05, 2012 | 2006 Lincoln Navigator
I have a waterway 48 frame pump that began leaking at the bottowm of the volute. Figured it could only be the o ring causing it to leak, I replaced that, but it continued to leak. Did not seem that the...
Thank you for posting your question here on
Your pump seal is the most likely culprit. As the water leaks around the motor shaft it will trickle down to the bottom and drip off. Double check your drain plugs first to be sure it isn't one of them dripping. Assuming they are not, it is the seal.
Waterway pumps use a press-fit 1000 seal. It is not an 'easy' seal change compared to most. You may want to take it to a pump repair shop for the seal change and the shop warranty that should come with it in case it is not done perfectly. If you do it yourself, get a piece of 1" rigid PVC about 8" long with clean-cut squared off ends to use as a driver.
Remove the front pump cover exposing the impeller. Remove the cover plate off the back off the motor to expose the end of the shaft opposite the impeller. Depending on the motor, lock the shaft with a wrench, screwdriver or allen key then spin the impeller off counter-clockwise to expose both halves of the seal.
Remove the old pieces completely and replace them. Put a SMALL bead of silicone caulk along the beveled edge in the seal plate, line up the metal cup making sure you NEVER touch either seal face in the process, and then punch it down with a mallet and the PVC pipe. The ceramic piece can get a small amount of a synthetic lube or just use a little soapy water to ease pressing it into the impeller recess again making sure not to touch the polished seal face. Use clean rags or pieces of paper to cover the seal as you work with it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at Positive feedback is appreciated once your problem is solved!
Jul 22, 2011 | Waterway Pump Volute CD WW
When i move my lincon star liking water.
This sounds like you have a problem with the water-pump, it will need to be replaced. This is quite a common fault and usually happens when the vehicle reaches 100,000km or more.
Let me know if you need more information.
Feb 28, 2011 | 2006 Lincoln Navigator
I have a coolant leak.2001 alero 4cy 2.4
If you had the engine replaced and have the same leak, it may be be somewhere else. You can rent a tool from most parts stores that pressurizes the cooling system. If you get that tool, top off the coolant and follow instructions to pressurize that system, you may be able to see where it's leaking. While it's under pressure, take a flashlight or shop light and look in all the main areas. (hose connections, radiator, water pump, ect)
Jan 23, 2009 | 2001 Oldsmobile Alero
Any service man that said it is easier and cheaper to buy a new one is seriously confused. A Fresh-O-Matic runs around $1,300.00 to $1,500.00, depending on where you get a price, and usual service calls on Fresh-O-Matics are around $150.00. I have loaners that are over 30 years old and they still work great and they use the same parts. I would recommend calling Lincoln Food Service 1-260-436-0735 or send them an e-mail at and see who the recommended service company is in your area.
Feb 24, 2008 | Lincoln 4000 Fresh-O-Matic Rice Cooker
Lincoln 4000 Fresh-O-Matic Rice Cooker Logo
506 people viewed this question
Top Lincoln Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Lincoln Kitchen Appliances - Other Expert? Answer questions, earn points and help others
