Question about Dell 946 All-In-One InkJet Printer
My fax machine recieves faxes but does not print them, it is a four in one printer.....it prints other things. What can I do??
  • 489 Answers
To fix this problem, you need to unplug the power adapter for at least 5 seconds. This will result in the loss of all stored faxes, so you may want to print an Activity Report before doing it so you can request the faxes be resent. There is a firmware update that is supposed to fix the problem. You can download it from: http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=202549
Posted on Jun 04, 2009
Our Brother 7820N Fax Machine/Printer is recieving faxes, but it is not sending them. It will dial the number then just beeps a few times. After trying two or three times it prints out an error report...
That sounds ok for me.
It is common thing what fax 2920/2820 should do.
Have you ever send fax to that same number previous?
Its probably problem with destination fax machine.
Feb 07, 2011 | Brother Office Equipment & Supplies
I am recieving fax but machine can not print it
When the fax comes through, is anything printed on the paper or not. if nothing is being printed on fax page, only blank page comes out then reduce the moderm speed for your fax. it will solve the problem.
Oct 01, 2010 | Samsung SF-565P All-In-One Laser Printer
Recieve the fax and print the pages well. But, when I send the fax to other fax it prints two black lines on the right side.
The problem should be from the printer fuser assembly, the other party will need to replace there fuser assembly on there printer, once that is done, the problem should be fix.
Take care.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Faxes are not being printed when sent - Machine
its recieved the fax in memory!The only time that happaens is when there's no toner or paper in the m/c
Feb 25, 2010 | Canon PIXMA MX310 All-In-One Printer
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Dell 946 All-In-One InkJet Printer Logo
97 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
