Question about Car Audio & Video
Resistor value for R136 in shneider amplifier.....
My amp was playin up for a day or two.....until i took it out and heard a rattle inside.
so i opened it up and a resistor fell out, which is now lost ( stupid me...i know).
where the blank space where the resistor goes its got R136 next to it.
so im trying to find out the value so i can replace it.
any help would be greatly appreciated...... im going out of my mind driving with no sound.
the product is schneider SPA-5000x 1 channel
  • Mark Skinner May 11, 2010
    Hello, It's going to be very hard to find the value. You need to get a service manual, it will tell you what each compent is and the value. Or maybe you'll get lucky and another person has the same amp and can tell you. Good luck. If you ever need anything repaired, amp,head unit, then I your man. I have my own business and and I'm also the cheapest you'll find for repairs. Thaks
  • Gregorius1 May 11, 2010
    Post a good pic of the component side of the board, bet I can figure it out.
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
I got an amp from my buddy who was going to throw it out cause he broke the 0.2 to 6 volt dial. He discarded the old broken part out of fustration. Anyone know the part number for said missing piece? ...
so we know a few things...
1. you guys are inside the amp removing board soldered components.
could be a good thing since what you can do to sleuth a solution is this...
a. know that the 'knob' is actually a variable-resistor that ranges resistance from a start value to a max value.
b. you can ascertain the range by opening a similar amp and testing the resistance range as you rotate the knob.
c. pick the mid value resistance and buy a cheap resistor of that value, then just solder the resistor in place of the two knob-control bread board connectors.
voila.
May 07, 2011 | Crunch Maxxsonics P1500.1 Car Amp
R40 piece is missing is that a problem
Hello crzykd129,
If a piece of a resistor has broken off, it's value has changed which affects other things in the circuit. It needs to be replaced with a new component to restore proper operation. The remaining portion is being severly overburdened everytime you power it on and it's just a matter of time until it causes some other part to fail.
Resistors are generic so try locating it by resistance value (indicated by the color coded bands), and wattage and replace it. Here's a source for all types of electronic components.
Hope this helps.
Aug 08, 2009 | Legacy Audio Blue Diamond LA1480 Car Audio...
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Exploded 5 resistors need a schematic
I don't have the schematic but if you can send me a photo of the inside of the amp, I may be able to tell you the values of the resistors. Many of the class D amps are clones.
babin_perry@yahoo.com
Oct 02, 2008 | SPL DK-2600D Car Audio Amplifier
Marshall AVT 150head no power
I would go ahead and take it apart, after you unplug it or course. if there is fuse on the back there will be one just off the ac line inside. These amps have an 12ax7 tube in them I beleive ,and large filter capacitors in them where voltage could be stored for a time after you unplug it ,but this is a fairly modern amp with bleeder resistors so it will be safe . you can wait over night to be safe, anyway you won't go touching the large capacitors anyway you are just changing a fuse. look for something like 2 amp or 5 amp in value. replace it with the same value.
Aug 26, 2007 | Audio Players & Recorders
Amp in protect mode
Check to see if the fuse is blown. If it's not, the amp is unfortunately fried. It would not be worth repairing the resistor in it
Apr 11, 2017 | Phoenix Gold Xenon-600.1 Car Audio...
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
