Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Flotec pump smells like burning plastic
My 1/2 HP flotek fp 4012 jet pump smell's like burning plastic when it runs. I've checked the voltage going to the pump and it's right where it should be.
    President:
  • 1,185 Answers
What size cable are you using to provide the supply
Voltage is one thing current is another
Thin cables will not provide the current to run the motor in its proper environment and will cause it to get hot.
On the rating plate of the pump you will find a voltage and current requirement that will tell you what size cable you need for your area ie 110vac or 240vac
Also need to allow for the distance the pump is from the main supply , the longer the run the thicker the cable is the rule as there will be fall off in performance if the cable is not up to it.
Posted on Jun 17, 2009
Waynerobbins@msn.comHow do you remove the water pump from the motor on a 4012 1/2 hp assembly
You have to remove the 4 bolts which are # 14 on page 9 of the instruction manual located at this site
http://www.depcopump.com/datasheets/flotec/FP4012-10,%20FP401215H-10,%20FP4022-10,%20FP4032-10%20manual.pdf
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Aug 12, 2011 | Flotec Corrosion Resistant Shallow Well...
Flotec pump model FP 4112-08 will not pump over 35 psi
If it stops pumping at 35psi you need a new pressure switch. If it just continues to run but doesn't build more pressure the problem is more likely a plugged point or air getting in due to the water table dropping.
Jul 14, 2010 | Flotec Corrosion Resistant Shallow Well...
What value starter capacitor for 1/6 hp Flotec sump
when a motor burns out this will happen , replace the pump.
Apr 02, 2010 | Flotec Corrosion Resistant Shallow Well...
I have a Flotec shallow well pump. The motor is buzzing but it will not turn.
could be bad bearings,obstruction in impeller,low voltage,failing capacitor.
Dec 20, 2009 | Flotec Corrosion Resistant Shallow Well...
My pump died the other night. I took it all apart and nothing is blocking anything. It smells like something is burning and when I opened it up oil went all over.It sounds like it is treying to work, bu...
Hello there:
The burning smell that you are smelling is the motor windings which means that the motor is shot
what probably happned is that the seals that seal the pump from the motor failed allowing the oil to get into the motor and as you know electricty and oil do not like each other so it fried the windngs on the motor ok
you can have the pump rebuilt for around $150 or just get a new one ok
I hope that this is very helpfull for you
best regards michael
Oct 30, 2009 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
I got a brand new Flotec 2 HP Jet pump and installed it but now it is overheating and smoke is coming out. Why is this happening and how can I fix it?
WAS YOUR NEW PUMP DUAL VOLTAGE? AS IN 115VOLT OR 220VOLT. IS IT WIRED FOR THE CORRECT VOLTAGE? NEED MORE INFO IF THIS DOESNT FIX. HOPE THIS HELPS. JODY
Aug 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Foltec 4012-10 motor get hots and kicks off
Sounds like a seized bearing. Many times the motor boosts its torque output to get over the initial inertia. and if the bearing seized, the motor running at normal capacity would not be strong enough to rotate. thus causing the rotor to stall and hence the motor getting overheated.
Aug 10, 2009 | Flotec Corrosion Resistant Shallow Well...
MY WATER FROM OUT OF THE PRESSURE TANK SMELLS HORRIBLE
Put a mixture of 1 cup bleach and water in the tank, let it set 24 hours, rinse well and see if that gets rid of the smell.
You didn't say what it smells like.......
Jul 14, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
328 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
