Question about IBM Wheelwriter 30 Typewriter
My IBM Selectric System 2000 Wheelwriter 6747/6747-2 has quit typing. The keys respond and the carriage moves but no type appears.
  • IBM Master
  • 3,594 Answers
The plastic cap on the print solenoid is probably broken. We sell them with installation instructions for 20.00 including shipping. DickyO Cleveland Business Machines 216-241-0027
Posted on Jun 04, 2009
Wheelwriter 6 Won't Type
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Feb 10, 2014 | IBM Office Equipment & Supplies
Carriage wont respond
Perhaps the L. Mar. is set there. Turn it on wait for the por sequence to complete, touch the mar rel key, back space to the far left, press L. mar key. If that dosen't do it tou must have some lights flashing and/or beeping, What lights and how many beeps?
DickyO
Feb 26, 2010 | Lexmark Wheelwriter 10 Series II...
I Have an IBM selectric system/2000 Wheelwriter 3
The platen probably worked itself out press firmly down on both ends of the platen it slould click into place. If it won't stay you will need a platen.
DickyO
Oct 23, 2009 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
My IBM Selectric II types the wrong letters. No matter which key I press a different letter will be typed. But there is consistency in that the wrong letter will repeat over and over again so its not...
Sounds like the cable might have slipped off the pulley, with the cover off, check all cables to the carriage assy. You need a tool like a spring hook to gently slide the cable back on to the pulley.
Jul 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric Typing carriage doesn't stop moving. Stuck key?
It sounds like a possible tab knockoff problem. This could be a small spring loose or broken in the escapement portion of the machine or the final knockoff in the tab unit out of alignment. You can try setting a tab before the end of the carriage by holding the carrier in place and using your other hand to press Tab Set, but the alignment may be just far enough off to keep you from actually setting the tab. One other thing that sometimes will cause the problem is the pitch setting lever is between the two pitches. Make sure your pitch setting lever is seated in its home position.
Mar 27, 2009 | IBM Office Equipment & Supplies
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
282 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
