Question about Xerox WorkCentre M-24 Color Copier
Error code 016-781
When trying to scan to e-mail, error code 016-781 appears. This error code is not listed in the manual. Can you tell me how to solve this?
4 Suggested Answers
  • 2072 Answers
SOURCE: Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Posted on Jan 11, 2009
  • 158 Answers
SOURCE: I am scanning to a PC using the FTP function.
when configuring scan set to anonymous instead of using a name and password
Posted on Oct 03, 2009
  • 2072 Answers
SOURCE: Hi We are unable to scan through our fuji printer
Set "Sub-net Mask" and "Gateway" of the main processor correctly.
From the destination server, check that you can identify the M/C with "ping."
From a Windows95 or UNIX machine to check that the FTP connection to the destination server is possible.
If the machine is a DC 3535, check that the Ethernet Crossover Cable from the ESS to the Network Controller is connected and is free from damage. Refer to the Network Controller service documentation for repair procedures
Posted on Aug 02, 2010
I get error 0c00400000020c
System Error: 0C0040
Problem
Description:
Error in Printhead Drop Detection. This error code appears when the
Printer detects that the same area of nozzles do not work in different
Printheads. The possible causes are either fibres or a piece of paper
in the Drop Detector or that the Scan-Axis reference is incorrect.
Corrective Action: Try the following:
Manually recover the Printheads and check whether the error still appears.
If the error does appear again, then check that there no fibres or pieces of paper in the Drop Detector.
If the error does not appear again, then check that the Scan-Axis
stop of the Carriage is not deformed too much (some slight
deformation of upto 0.5mm is normal, but if it is bigger than that,
then replace the Carriage Assembly and recalibrate the Printer).
If the Scan-Axis is OK also, then replace the Drop Detector or the Service Station Assembly and recalibrate the Printer.
Found on the Service Manual
Aug 05, 2014 | HP Designjet 5500uv 60 IN Printer
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Want too delate a name from yahoo address book/error code 40402
This is a yahoo server error code
It can happen if you try and try and amend contacts from your friends list before your address book
Go to yahoo mail page > contacts > address book >check box next to contact to be deleted > delete
Open Messenger.
Right click on contacts avatar > delete
May 03, 2010 | Microsoft Windows 98 for PC
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
Nov 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Tried to send e-mail error host SMTP could not be found error code ox8oocccod do not understand what that means
It sounds as though you're using Outlook to send email to and from and ISP and not to or from a Microsoft Exchange server. If so, then the following applies.
The error message means that there is a configuration problem with your email account settings. This error usually happens when an error has been made when specifiy the name of the outgoing (SMTP) mail server.
Note: It may be necessary to contact your ISP to obtain their specific mail server information. The standard port number for Incoming mail (POP3) is 110. The standard port number for Outgoing mail (SMTP) is 25.
Here's what you need to do to verify your settings:
1. Contact your ISP to obtain their specific mail server settings.
2. Open Outlook
3. Click on the "Tools" menu item then click on "Account Settings".
4. Make sure you are on the "Email tab" of the account setting dialog box.
5. Double click on the email account that is listed under "Name".
6. The Internet Email Settings dialog box will appear.
7. Look for the heading "Sever Information". Below that heading you will see Incoming and Outgoing Mail Server . Verify the names of your mail servers match the information given to you by your ISP.
8. If your ISP have provided you with port numbers other than those listed in the note above, perform steps 9 to 12. Otherwise proceed to step 13.
9. From the Internet Email Settings dialog box, click on the "More Settings" button.
10. Click on the "Advanced" tab.
11. Change the Incoming and Outgoing mail server ports to match the information provided by your ISP.
12. Click the OK button to save the changes.
13. Click on the "Next" button.
14. Click on the "Finish" button.
15. Click on the "Close" button to colse the account settings.
Outlook will now be configured properly to send and receive Internet Email.
Sep 13, 2009 | Microsoft Office Home and Student 2007...
BT Yahoo! e-Mail - Error Code 5
generally this error will remove by itself... first of all close the outlook and try again using the email using yahoo mail thru ur browser ..this will solve the issue....
Jun 02, 2009 | Yahoo Mail
CE-02 error code when scanning on SHARP MX-M550U copier
ce error means not hooked up property to your email server
Feb 12, 2009 | Office Equipment & Supplies
Rinnai 606tra error code 31
since the e mail you sent to me was do noy reply i will try to get my point across here.
i posted my question on your 10 buck forum the answer i got was read the manual and now after posting on your free forum the reply i get is to try posting in the 10 buck forum. sound like a run around to me
Oct 04, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Xerox WorkCentre M-24 Color Copier Logo
5,136 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
