Question about Vantec iON 2 VAN-460N (VAN460N) 460-Watt Power Supply
Graphics Cards causes computer to not display
I have just finished building my computer and it works perfectly fine. Today I tried to put in my 7800 GT but when I plug it in there is no picture on the monitor just black. Everything sounds the same just no picture at start up. I have a Gigabyte GA-VM900M Core 2 Duo E6420 Vantec ION2 460 Watt PSU 2 GB Ram 667 if that helps. (It worked perfectly until I put graphics card in)
  • toxicitysoad Jun 05, 2009
    I have tried it set on PEG and on PCI E but it still won't work.
  • 4,806 Answers
Hi there.
I'm working on the assumption that the graphics card is a PCI Express card.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Posted on Jun 04, 2009
  • Lee Hodgson
    Lee Hodgson Jun 05, 2009
    With the card out go into the bios and set the bios to default settings, save the changes and exit the bios.
    Then try the card again.
  • 585 Answers
Did you plug a 4-pin power plug into the end of the card? (extra hard drive plug)
Posted on Jul 13, 2009
As the previous poster has suggested your Onboard Video Graphics card is set to load first. You will need to enter the BIOS and set the Primary Display to PEG1 (which stands for PCI-Express Graphics 1) That is the way it was on my GA-MA790GP-DS4H only i had to make sure to specify which PCI Express card to use as i have 2 of them.
  • troubled1367 Jun 05, 2009
    If that didn't work then you may have a faulty card. Try the card on another board (possibly a friend's computer) to see if it is just your graphic card malfunctioning. It seems as though the motherboard is not recognizing that you have indeed inserted a graphics card into the PCIe Slot.
I have a problem with a X1550 video card, 512 Mb, it seems to have bad contacts on the pci express slot. When i turn on the computer it displays only vertical lines, after repositioning the video card in...
looks like that your vid.card has a compatibility issue.
but since that you've tested this w/other computers and still the same?but your computer works on other vid.cards?
that means,there's a big chance that your vid.card is already busted.
Sep 09, 2011 | Power Color POWERCOLOR ATI RADEON VC X1550...
Computer powers up but monitor wont displays from video card, so I swithch to motherboard connectors
This may be because your graphics card is not compatible with your motherboard, If you are using a newer Intel motherboard for example with Intel HD Graphics, there may be issues with using an older GeForce card with the board.
Mar 07, 2011 | XFX GeForce 7800 GTX, (256 MB) Graphic...
Cannot get recovery disk for my computer to work
ok what you need to do is put the disk in the cd drive then shutdown your pc then start it again wen the first screen shows up usually displaying the brand name with some options at the bottom of the screen select the option, boot options and select boot from cd rom and that should start the recovery process which will guide u through itself
Aug 31, 2009 | Dell (TD789) GeForce 7800 GTX, (256 MB)...
Apacer Micro Sd (adaptor) not read by computers.
well i would see if you have the updated drivers for the card reader.. if not it might be a older computer that is not savy with the new high tech stuff we have today.... i hope this helps.... let me know
Jul 31, 2009 | BFG Technologies GeForce 7800 GTX OC ,...
Driver don't work with Palit 9600 GT 1GB
this can be an cooling issue with 2 graphics cards in your system or it could be caused by your SMPS, it should be 700w or above to handle such a system efficiently.
Jul 03, 2009 | Palit Microsystems GeForce 9600 GT, PCI...
Error code 43
Uninstall both video cards, disable the integrated card in the bios, and then reinstall the stand alone video card. If you continue to have problems, please post what motherboard you use and what error code device manager gives.
Jan 14, 2009 | Nvidia GeForce 6200 AGP Graphic Card
A8N-SLI Premium & NVIDIA GeForce 7800GT
Sounds like your getting conflicts with running two different card drivers. I've never heard of running a PCI and a PCIe card at the same time.
Jan 09, 2009 | ASUS GeForce 7800GT, (256 MB) PCI Express...
I am on a dell xps m170 with a nvidia geforce 2 go 7800 card. I have connected it to a 1080p 40 inch Samsung lcd. How do I make it fill the screen on the TV I have a blue border all around the desktop. My...
go into your display properties and you may have to look around for a sec, but there is a setting in there that will say enable boarder uncheck this and you will no longer have the boarder around the screen
Dec 11, 2008 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
Evga 8600 gt broken
It is probably cheaper and less time consuming to replace the actual video card. Many manufacturers sell only finished products and you will not be able to use a different chip or it will cause problems.
I hope this helps.
Nov 09, 2008 | Evga e-GeForce 7800 GTX, (256 MB) Graphic...
New graphics card seems to be running games slower
hi im wesley waz the games running fine before with the same graphics card or with a different one?
Jul 20, 2008 | Computers & Internet
Vantec iON 2 VAN-460N (VAN460N) 460-Watt Power Supply Logo
136 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
Willem.
Willem.
Piyal Perera
Piyal Perera
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
