Question about Whirlpool LSB6200KQ Top Load Washer
Clothes don't spin dry
When I take my clothes out of the Whirlpool front load washer, they're still quite wet. What can I do?
    Problem Solver:
  • 4 Answers
It probably the belt because mine is doing the same thing . I bought a belt now I have to figure how to get the belt back on.
Posted on Jun 04, 2009
Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
Jan 08, 2015 | Whirlpool Washing Machines
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not spin drying the clothes
check to make sure the pump is not restricted or drain hose kinked.
May 20, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool LSB6200KQ Top Load Washer Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
