Question about Lantronix UDS1100 (UD110000201)
Lantronix UDS 1100 freezing my software and hardware
I am using a lantronix UDS 1100 with its lantronix port redirector to convert an rs232 connection from a handscanner device to ethernet then receiving the data at a computer using some time and attendance software.  i can connect to the scanner, and receive data from it using the software (novatime 2000)... when i try and rdownload handmaps from my computer to the scanner both the software and the scanner freeze up... the handmaps may be large data files and i think the obstruction is when the data goes through the lantronix device.  what settings on the lantronix may be relevant? thanks
  • Anonymous Sep 18, 2008
    how to assign ip to lantronic using command prompt
I would check your flow control on both the device and on the UDS1100. Also make sure your baud rate, stop bits and parity match
Posted on May 02, 2008
Lantronix UDS1100 what are the pin connection to emulate com1 on a PC
Please see the link here below for the complete manual.
If you go to page 70 you will see the complete pin layout for RS232, if you need to connect it to a PC with a 9 pin RS232 port you can see the equivalent on page 72.
Please let me know if you need more details.
Mar 15, 2011 | Lantronix UDS1100 (UD110000201)
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
I need a laptop with RS232 port. What model should I get?
RS232 is now not being fitted to laptops This has become old technology. If you have devices that require connecting via an RS232 There are USB cables that emulate the connections of an RS232 that can be set to a com port to fool the device that it has the rightr connection. Look on Ebay there are quite a few at various prices, most from Hong Kong. I have bought aqnd used them to connect my radio scanners and Scancat software to program Amateur radios quite succesfully, as well as to run my old HP A3 scanner
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Toshiba Satellite M35X-S149 Notebook
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Feb 22, 2010 | NEC Lands Phones
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
Need drivers for nikkai usb to serial converter rs232
I purchased the Nikkai USB to RS232 adapter from Maplin and could not get the device working. (Maplin staff not much help!) The lead uses the Prolific PL-2303 device but Prolific do not supply the drivers to end users.
However I found the drivers that appear to work at:
This then recognises the lead as a COM port. So far everything seems to work OK.
(Null modem check and basic 9600 data transfer.)
I hope that helps everybody.
Dec 08, 2008 | Computers & Internet
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note can download the RS232 software from below link and test the scanner
Oct 30, 2008 | Metrologic Instruments MK9540...
UDS10 reconnection problem
Try the LS100 from, it has a better warranty (5yrs vs 1yr) and its about half the price of a uds-10. We've had the same experience with the four UDS-10's we have and now 3 of the four have stopped working and report the following error: "FATAL ERROR 01/Setup memory: Contact tech support". I called there tech support and the guy (Marty) actully told me that the units have exceeded their life expectency. They all failed within the first ~22 months of operation. Working in a school district we cannot afford to keep doing the same thing over and over and over again, so our next project which involves 15 building will all use the SENA LS100 product and save the district money and have way better support and warranty. Thanks goes to "tech support" person Marty at Lantronix.
Oct 26, 2007 | Lantronix (UDS-10-01) Terminal Server
Lantronix UDS1100 (UD110000201) Logo
852 people viewed this question
Top Lantronix Computers & Internet Experts
David Gust
Are you a Lantronix Computer and Internet Expert? Answer questions, earn points and help others
