Question about Lexmark E232 Laser Printer
Lexmark E232 - BLACK SMUDGING on sides of print
Every page printed has vertical black lines plus black smudging along edges. Roller seems dirty but even after wiping clean it gets dirty again and problem persists.
Help please...!
  • trev289 Jun 04, 2009
    Have replaced toner cartridge several times - problem persists.
    Problem Solver:
  • 7 Answers
Unfortunately, you have a bad Photoconductor. You can try cleaning all the contact points first, to see if that solves you problem, but if the dark areas are always in the same spot, then the photoconductor is either worn out or damaged.
Posted on Jul 16, 2009
    President:
  • 4,402 Answers
Try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
How do I correct black smudges when printing?
If the smudge marks are down the edges of the paper, the PC Kit needs replaced.
Feb 13, 2015 | Lexmark E232 Laser Printer
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon LBP 2410 Lazer Colour Printer -
Printing not dark enough or varied in darkness
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
Jun 07, 2008 | Canon Office Equipment & Supplies
Edges of prints are black smudged
MAY BE DRUM UNIT IS END OR LASER UNIT
JUST SEND A COPY VIE MY MAIL SHAMMINOLTA@GMAIL.COM
Dec 14, 2013 | Brother MFC-8460N All-In-One Printer
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
Smudging with black & white text
try opening up the properties for the printer and finding the tab marked tools. once there use the alignment and cleaning tools see if that helps
Nov 11, 2009 | Office Equipment & Supplies
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Color lines/dashes at top and middle of page when printing.
Amand321,
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
Gremlin11
Sep 29, 2008 | Brother MFC-9420CN All-In-One Laser...
Lexmark E232 Laser Printer Logo
1,096 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
