Line in left side of screen
I have a 46" Mitsubishi LCD HDTV that has a line on the left side of the screen from the top to the bottom. The line had only been there when the TV was 1st turned on and would go away after about 15 mins.
I called Mitsubishi support and was told to reset the TV using the TV reset button on the side of the screen. After doing so, the line is constant on the screen and does not go away after it "warms up "
LT-46133
TV was purchased 10-07
  • clark_c6161 Jun 08, 2009
    I did not buy the extended warraty for this TV
    Who is mits ?
  • 197 Answers
Bad panel call mits has 2 year extended warraty for panel, need to call for authorized service center
Posted on Jun 07, 2009
White Band On Screen - Remove It!
if a white band is seen---go to a blank or unused video input and examine the screen---both sides---if it is seen on both (even if more so on one side) you may have burned the screen by using the 4x3 format.
If this it is permanent damage.
Mar 31, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
2 year old Mitsubishi LT-46149 46" LCD Flat Panel
Does it come and go? I would try reseting the ribbon cables between the LCD panel and the T-CON board first.
The Flexible Printed Circuit BoardS (FPCB) are ultrasonic welded to the LCD TFT panel, they are not SOLDERED on! The connections do get bad due to very delicate nature of how the LCD panels are made. You can also try squeezing the around the top area of the screen where the lines are to see if the lines go away.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 14, 2010 | Mitsubishi LT-46144 46 in. LCD HDTV
Black line down the side of both sides of the screen about two inches from either side
mitsubishi covers this problem under ext mfg warranty for two years after date of purchase 1800 332 2119
Feb 27, 2010 | Mitsubishi LT-46144 46 in. LCD HDTV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
Jun 26, 2009 | Mitsubishi WD62527 62 in. LCD HDTV
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Mitsubishi 46in. LCD
The TCON board at the top of the panel is causing the issue. You will need to replace the whole panel.
When the set warms up, the TCON behaves. Replace the panel now to avoid what will eventually become a permanent line (if not several)
Jan 19, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
