Question about Panasonic KX-TG6071M Cordless Phone
Expandable handset will not register
I followed the instructions to register my new expandable handset but when I press the menu button followed by pressing the double 0's, the handset states INVALID . I removed the batteries, pressed the center row of buttons, which were all advised, nothing new happens. I can't seem to get passed the ''press LOCATOR'' message. The handset states that all hansets are registered. This handset would be the fourth for the base. I purchased two handsets, one has registered and one has not. Please help. Thank you.
Sandra
    Problem Solver:
  • 12 Answers
It sounds like the base unit has other handsets registered to it. This is why you are getting the message "All Handsets Registered". You will need to reset the base unit in order to register your two handsets.
Hopefully this will help you. Put the phone in an easily accessible spot where you can plug it in and unplug it easily. Unplug the phone, wait a few seconds, and plug it in again. Now, unplug it again, and before you plug it in once more, hold down the Locator button as you plug it in and all lights should flash on. It should emit a long beep, which means it has reset. If not, you will need to unplug it once more and hold down the Locator button again as you plug it in.
Once it beeps, it should allow you to add your handsets. If there is nothing on the handset display, press the off button, menu, then 001. It should then read "Press LOCATOR on base for 3 sec, Then press ok". At this point, you will need to hold down the Locator button until it flashes before hitting okay. The handset will be registered when it reads "Handset 1 Registered".
If this doesn't work, I would call Panasonic.
Good Luck!
~Julia
Posted on Jul 22, 2009
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
My CL80101 will not register, what to do?
1. When the new handset says "Connecting..." and goes
nowhere else, enter *331734 [menu] and it will soon
beep and display "Not registered"
2. To register the new handset to your base: on the base
press the "Handset Locator" button and hold it until the
"in use" light comes on ( ~ 4 seconds ), then release the
button and set the new handset into the base phone
cradle. After ~ 30 seconds it will beep and display
its "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset
in turn: press "Handset Locator" ~ 4sec
( in-use light on ), set handset into the base
cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Apr 21, 2016 | Lands Phones
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
and it will soon beep and display "Not registered"
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
When the orphaned handset says "Connecting..." or
"Out of Range..."
is still blinking.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from
its original base...simply de-register it from the old base and
re-register it to your base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Mar 04, 2015 | AT&T El52300 Cordless Phone
Deregister procedure for at&t el52400 handsets
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
I had to purchase a new AT&T cordless phone system since my last set was destroyed by lightening. My old system was CL82409 and my new system is CL82209. I have 3 expandable handsets from the old...
According to the manual starting on page 52, you need to de-register all handsets then re-register the handsets one at a time. The manual covers both cordless model numbers so the handsets should be interchangeable. I have included a link where you can download the manual if you need it.
http://att.vtp-media.com/ecp/documents/product_Product/127/UserManual/1082/cl82209_manual_i3.pdf
Mar 27, 2011 | AT&T Lands Phones
Hi There.. Lost instructions..wanted to know how to change the handset setting/line settings.. want to change handset to different base ?? Hopefully you can assist? Thanks
First, you need to de-register the handset from the current base. Then register it to the new base. On the handset, press Menu then navigate (up/down arrows) to Handset Settings and press OK. Next navigate to Registration and press OK.
For deregistration: navigate to Deregister then press 3 3 5 . Then select which handset to deregister (1-6) (the handset number will flash when it is selected) and press OK. Select Yes and then OK. When the deregistration is complete, press OFF.
For registrations, navigate to HS Registration then press OK. Then move to the base and press and hold the Locator button until the registration tone starts. If all the handset ring, press the locator button to stop the response and start over. Within a minute and a half of the registration tone starting, press OK on the handset and wait until a beep sounds and the symbol on the screen stops flashing.
The user's manual is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG1033S.O#ts . It's in the tab marked Operating Instructions. This will provide additional setting information.
I hope this helps.
Nov 29, 2010 | Panasonic KX-TG1033S Cordless Phone
Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Sep 23, 2007 | Lands Phones
Verge cordless phone system v581tad
I believe you have the expansion capacity of the phone all used up. The phone cannot register any more handsets until you delete the handset registered that is not in use. First check the handsets and see what handset numbers they carry. It should be #1,#2,#3,and #4 if it does not then you will have to delete the one that is missing or if it is then delete handset #5.To do this you will have to use one of the handsets registered to the base. First Press the MENU/ OK button then scroll down to ADV,SETTING then Press MENU/OK then scroll down to DEREGISTER then Press MENU/OK. Then ENTER HANDSET PIN would show, if you have not changed the pin enter 0000 if you have enter your pin member. From the next options select HANDSET and press MENU/OK from the next set of options select the handset number you want to DEREGISTER and press MENU/OK from the next option select YES then MENU/OK. Then try to reregister the new handset To do this Press the MENU/OK button then go to ADVANCE SETTING press MENU.OK scroll to REGISTER then press MENU/OK Select the base number displayed then press MENU/OK. PLEASE WAIT will appear. Then from the base press and hold the PAGE button until the handset prompts you to ENTER PIN # .Enter 0000 OR your pin number then you will see PLEASE WAIT. A tone will confirm the handset registration.
Apr 03, 2007 | Uniden Cordless Phone
Panasonic KX-TG6071M Cordless Phone Logo
279 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
