Question about Motorola Mobility RAZR V3
One Time Entry
When I used to select 'One time entry' to enter a phone #, it would automatically be on numeral setting.
Now when I do that, it is automatically letters. Cannot figure out how it happened or why as one time entry would only ever be a phone #.
    Sergeant:
  • 316 Answers
Check your text button settings
I think it's the star button every time you hit it it will change the type of text from capital to lower case to numbers to symbles ect.
If it is not the star button look for the button with the arrow on it pointing upwards
Posted on Nov 01, 2007
How do I set the time?
S E T U P
SET UP is performed once during
installation to set the internal CLOCK, ASTRO (sunrise/sunset)
times and HOLIDAY references. After entering and okaying the
ASTRO Zone, the timer will display calculated "center of time
zone" times when prompting for sunrise and sunset entries. You
may OK these, enter actual sunrise/sunset times or enter offset
times for early or late ASTRO operation. Sunrise time must be
before noon; sunset time must be after noon. Sunset must not be
within 5 hours of sunrise. Both sunrise and sunset must be
entered, even if only one is used for switching. If neither is
required, you may skip ahead by pressing HLDY or PROG keys.
(See map pp. 24-25 for details.) Holidays are entered with 2-digit
reference numbers; a chart for recording the date(s) is located on
page 22. Leap years are preset through the year 2094
PROGRAM is used for entering or
changing the switching schedule for loads wired into the time
switch. You can program circuits separately or concurrently. Each
entry affects loads whose Enable switches are in the enable
position at the time of data entry (2 circuit models only). The
time switch is shipped in a 12-hr. AM/PM mode; you can change
to 24-hr. by removing a jumper on the circuit board (see Special
Instructions). It can store a minimum of 400 events, depending
on the data type entered.
The time switch prompts you through SET UP and PROGRAM
with LEDs that advance after each entry. There are five important
points to remember:
1) The RUN/SET switch must be in the SET position to enter,
review or change data.
2) You must press "OK" after each entry, before starting the next.
3) You must press AM or PM after entering time (unless
programming Sunrise and Sunset or in 24-hour mode).
4) When in PROGRAM you must select the loads you want to
control with the Enable switches (2 circuit models only).
5) RUN/SET switch must be returned to RUN position to enable
automatic control and to save changes to data.
KEYPAD
SUN
MON
TUE
WED
FRI
SAT
DY
ND
WK
WK
6
7
8
9
These keys are used for most data entry. Note dual functions,
numeric or day specific. Using the day group keys WKDY,
WKND and ALL (for all 7 days) greatly speeds the process.
The keypad keys are only functional when the RUN/SET switch is
in the SET position. Pressing keys when in the RUN position will
cause a message to scroll, explaining the function of that key. Press
any key once to stop any of the scrolling error or help messages
You must press AM or PM after entering time data (except Sunrise
or Sunset) unless in 24-hr. mode. Programming fixed times for
ON and OFF events does not require PULSE, INTVL or ASTRO
keys. Multiple ONs or OFFs can be entered by pressing OK
without programming the alternate OFF or ON. Multiple OFF
times are frequently used to "sweep" off loads which have been
manually switched on after normal occupancy hours.
PULSE and INTVL (Interval) are length-of-time based options.
Maximum Pulse is 127 sec.; minimum is 1 sec. Maximum Interval
is 6 days, 23 hrs., 59 min.; minimum is 1 min. To program Pulses
or Intervals, press the PULSE or INTVL key after entering a Switch
On or Switch Off time; then enter the required duration and press
OK. Note after ON Pulses or Intervals have timed out the load
will be OFF, and after OFF Pulses or Intervals have timed out the
load will be ON, regardless of the load state prior to the start of
the Pulse or Interval. The INTVL and PULSE keys include a
temporary override function with a maximum length of 6 days, 23
hrs. and 59 min. for the interval or 127 seconds for the pulse. To
program an interval or pulse for override, select SET, enable the
circuit, press PROG, press INTVL
or PULSE (without selecting a
day), key in the interval or pulse
Intermatic ET70115C User Manual Page 4
Mar 11, 2015 | Intermatic ET70115C Electronic Energy...
I have a vtech Dect 6.0 #6041 dual handset cordless phone but do not have a manual for it. I have tried numerous times off and on for months to view the manual online, however it only ever lets me view...
To delete a single entry from the call log, press CID/down. Use up/down to scroll to the desired entry and press MUTE/REMOVE. To delete all entries, press CID/down, then press and hold MUTE/REMOVE until it display "DELETE ALL?". Press MENU/SELECT.
To store a directory entry, Press MENU/SELECT twice to enter the DIRECTORY. Use up/down to reach "STORE" and then press MENU/SELECT. The screen displays "ENTER NUMBER". Use the keypad to enter the number and then press MENU/SELECT. The screen displays "ENTER NAME". Use the keypad to enter the characters and then press MENU/SELECT. The screen displays "STORED" and you'll hear a confirmation beep.
You should be able to download the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/85/UserManual/245/6041_Manual.pdf
Jun 22, 2011 | Vtech Cordless 6041 Phone
How to change time and date
Follow this procedure to set the current date and time.
1. Open all three one-touch speed dialing panels.
2. Press [Data Registration]
3. Press [up arrow] or [down arrow] until <TIMER SETTINGS> appears, then press [Set]
4. Press [up arrow] or [down arrow] until <1.DATE/TIME SETTING> appears, then press [Set]
5. Register the current date and time using the numeric keys. Use 24-hour notation to enter the time (eg. 1:00pm as 13:00)
You can also press [>] or [<] to move the cursor without changing a number entry. To restore the previous entry, press (c) (clear)
6. Press [Set]
the message<DATA ENTRY OK> appears on the screen for a few seconds.
7. Press [STOP] to return to the Standby Mode.
May 13, 2011 | Canon MX700 Office All-In-One InkJet...
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
HOW TO SET DATE & TIME
To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
Press the "SET" button 2 times until you see: USER SETTINGS - 1. DATE & TIME.
To open the DATE & TIME Menu. Press SET. Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR. Press SET to "lock in" the Date and Time.
These instructions come directly from the User's Manual.
Hope this helps.
Mar 29, 2011 | Canon L220 Plain Paper Laser Fax
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
How to change from predictive text on my razr 3i
Press # in a text entry screen to select an
entry mode
1 Your Primary text entry mode can be set to any iTAP® mode or tap mode(indicated by 1).
2 Your Secondary text entry mode can be set to None, or set to an iTAP
mode or tapmode (indicated by 2).
123 Numeric mode enters numbers only.
@ Symbol mode enters symbols only
Jul 13, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Time & Date
1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
2. Press the "SET" button 2 times until you see:
3. To open the DATE & TIME Menu. Press SET.
Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
Motorola Mobility RAZR V3 Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
