Question about Amcor AL10000E Air Conditioner
Water leak My unit is leaking water. The drain hose is not plugged. What can I check before I do anything else? thanks!
  • nramkuma Aug 07, 2008
    My airconditioner leaks water from the bottom. I tried connecting the drinage hole to the hose and also totally closing it with rubber cork and the valve. In either case, water leaks from the bottom of the ac - i turned it over and say there were 3 holes on the bottom and water leaks from it. Is this a faulty AC ?
  • 236 Answers
First you have to unplug or "off" the circuit breaker, then install the drain hose.
Posted on Dec 31, 2007
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
I have a frigidare gallery ultra quiet III that is approximately 10 years old. It is not draining water to the point that it is leaking on the kitchen floor.
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Nov 03, 2009 | Frigidaire Dishwashers
Leaking unit
check to ensure that the drain hose is not touching the side if the water storage bin. if still no luck then watch unit when running to assess the leak point............maybe a hairline crack in water container
Oct 30, 2009 | Heating & Cooling
Water filter leaks replaced filter with bypass water leaks from drain holes underneath
In the very back of the unit, there is a black rubber drain hose that is supposed to drip into evaporator tray that is mounted on top of the evaporating tray. Check that hose is not plugged and that water is draining in tray.
Sep 15, 2009 | Refrigerators
Water leak from bottom freezer door
If you remove the back cover off the unit, you will see the compressor with an evaporator tray, make sure the little drain hose isn't plugged and that there is water in the evap tray from drain hose.
Jul 22, 2009 | Refrigerators
Water leak from Kenmore elite
If the leaks happens during drain cycle, this is usually because of a leak on the drain pump hose, or because of a faulty drain pump that is leaking.
As the appliance must be taken apart and the pump may need replacement, it is better to call a repairman to do the job.
Check that leak is not from drain hose, from water supply hoses, or from gasket first.
Dec 29, 2008 | Kenmore Elite HE4 Electric Dryer
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Amcor AL10000E Air Conditioner Logo
208 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Shehu Pro
Shehu Pro
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
