Question about HP Officejet 5610 All-In-One InkJet Printer
When I dial the fax number the tone is so loud how do you lower
I have the HP Officejet 5610 All-in-One and when I dial the fax number the tone is so loud. How do you lower the tone? It is presently working just fine and I do not want to try and change something without help. The tone is so loud it disturbs my coworkers because we are in such close proximity to each other. I really appreciate your help.
hashir4u
  • 79 Answers
SOURCE: HP Officejet 5610 stopped printing
turn the printer on and unplug the power cable from the back of the printer without turning the power off
press and hold :
OK and CANCEL, while keeping them on hold put the power cable back in ... it ll do a full NVRAM reset on it .. then it ll prompt u for the language and country follow the steps it ll be resolved ...
Best of luck
Posted on Jun 15, 2008
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
professor_sc
  • 180 Answers
SOURCE: HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Posted on Nov 29, 2008
leroyal
  • 2120 Answers
SOURCE: No dial tone on fax machine
Yes, all fax machines are analog.
Posted on Mar 03, 2009
SOURCE: hp j3680 fax/printer is loud
Press on Setup--> then scroll down and select Basic Fax Setup--> then scroll down and select Ring and Beep Volume and reduce it.
Posted on Apr 24, 2009
Can not send or receive faxes. Have successfully performed and passed the 6 components of the HP Fax test. Can hear dial tone when attempting to fax.
Dial from printer to your mobile phone sense the ring then send the fax sense the fax tone if fax tone not hearing you replace formatter ...
Sep 08, 2011 | HP Officejet 5610 All-In-One InkJet...
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610 All-in-one can recieve faxes but not send, when sending a fax i always get the busy tone. connot understand why, recieves faxes prefectly.
Have you set for the proper dialing? there's a choice for pulse or tone dialing, you probably need tone dialing. Also the number needs to be put in just as you would dial on a phone.
Jul 24, 2009 | HP Officejet 5610 All-In-One InkJet...
When we are sending fax getting communication error
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab49
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp j3680 fax/printer is loud
Apr 08, 2009 | HP J3680 Officejet All In One Printer
5610 issue
dial 9 then pu in 4 to 6 ",,,,,," then the number.
old fashion fax method, don't knock it, it works
Dec 05, 2008 | HP Officejet 5610 All-In-One InkJet...
How I can recive fax
If you can receive you should be able to send. Is the setting on your printer on tone or pulse dialing? I have a 5610 and just plugged it in and started playing. Can you let me know if it dials and if it does what sounds do you hear? If it dials the problems might be related to the tone and pulse dialing. If it doesn't then let me know what and how you installed your software? Is it connected to a PC or stand alone?
Nov 11, 2008 | HP Officejet 6310 All-In-One InkJet...
How to send a fax
there should be a command that allows you to SKIP that part. you put the document in, dial the fax number, and when you hear the tone, press send.
Aug 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
530 people viewed this question
Seeker5211
Seeker5211
