Question about Brother MFC-465CN InkJet Printer
WHAT IS DR MODE AND HOW DO I TURN IT OFF - Brother MFC-465CN InkJet Printer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
DR Mode is "Distinctive Ringing". You can turn it off in the menu (Menu -> Fax -> Other, if i recall correctly).
Posted on Jun 04, 2009
My brother mfc6490cw says dr mode what is this
DR stands for distigntive ring.
Before you are able to change the receive mode, you will need to turn off DR.
To turn off DR press MENU, then the down arrow until FAX and press OK. Then with down arrow choose MISC and press OK. Then with down arrow chose DISTINGTIVE and OK, then down arrow until OFF and press OK.
Jun 06, 2010 | Brother MFC 210C All-In-One InkJet Printer
Intellifax 2820
DR mode means that the distigntive ring feature has been activated so it will not let you change receive mode. You need to turn off DR first. Press menu/set then 2, 0, 2, then press the down arrow till you see distigntive off then press menu/set.
Now you should be able to change the receive mode to fax only!
May 29, 2010 | Brother IntelliFax-2820 Laser Fax
Can't set mode to receive fax, read through manuel says DR mode in use. fax does'nt pickup when a fax or call comes in stuck in manual.
DR MODE is in use means that your machine is setup with the distinctive ring feature, to turn it off follow the directions below.
Turning off the Distinctive Ring
1 Press Menu/Set, 2, 0, 2.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
Then you will be able to change the receive mode.
Apr 16, 2010 | Brother MFC 210C All-In-One InkJet Printer
After having been visited bt Dr Guard and
Dr. Guard and AntiMalware defender has nothing to do with the issue you are encountering right now. most Laptop has diagnostic leds depending on whos the manufacturer. i suggest to call aspire tech support.
Mar 07, 2010 | Acer Computers & Internet
Fax is stuck on manual mode. how can I change. When I try to change modes, is says that DR mode in in use.
I had this problem too, I just fixed it! DR = DISTINCTIVE RING, this means you have it turned on. To turn it off go to menu, fax, miscellaneous, distinctive and select OFF. Now go to back to initial setup and select your mode!
Mar 03, 2010 | Brother MFC-440CN InkJet Printer
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
drrjain3@rediffmail.com
Apr 15, 2008 | Nikon Coolpix S3 Digital Camera
How to enable Long Document mode?
As per the manual...
Press "New File" and "Count Only" buttons at the same time till they flash. Then hit the "New File" button to cycle through options. U10 is the normal/long doc mode. Change from 0 to 1 by hitting the "Count Only" button. Then to save and get out of User Mode hit the "Stop" button. The manual recommends only having long enabled when needed, it will slow down processing when using auto-detect length setting.
Feb 10, 2008 | Canon DR-9080C Path-Through Scanner
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Brother MFC-465CN InkJet Printer Logo
160 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
