HP LaserJet 1022 won't print unless i manually push button. it shows its set to automatic print, but doesn't work
  • 39 Answers
Ceck your driver settings on the computer. It sounds like te driver is defaulting to MANUAL FEED instead of auto-select.
In some cases, deleting the printer from the computer, unplugging the printer's cable, restarting the computer and then reconnecting the printer may solve these types of problems. Follow the on-screen prompts to reinstall the printer's driver using the original disk.
Posted on Jun 04, 2009
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
How do you do a print test showing number of pages printed on an HP LaserJet 1022 printer?
Press the Go button until the green light starts flashing and the motor starts. The configuration page prints.
Go button is next to the Cancel Button ( X )
Oct 15, 2010 | HP LaserJet 1022 Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Spooler system is not running in 1020 laserjethp printer
start button
run
type services.msc
select print spooler
right click and select start
select properties and make sure it is set for automatic
Sep 11, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Is it possible to take mirror image printing using by HP Laserjet 1022
That works as the Driver and application( End user is using) settings.
This can be done from software not hardware.
Jun 01, 2009 | HP LaserJet 1020 Printer
Must push the green button to print
Strictly in the user settings from the PC side.
Feb 12, 2009 | HP LaserJet 1320 Printer
HP Laserjet 1022 does not print the full date in voucher
adjust the page setting through pagesetup .and then check out in the print preview first before giving the print command.
Dec 10, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
498 people viewed this question
k24674
jasbo
jasbo
