Question about Panasonic SC-HT680 System
Have sc-ht700 system
Cd tray hits something when about 1/4 way out. will not open.
    Problem Solver:
  • 6 Answers
Re: have sc-ht700 system
Try taking the cover off and seeing if anything has jammed it.
Posted on Nov 08, 2007
0 characters
3 Points
I have the Panasonnic SC-HT900/SC-HT700 and wondering if it can fully used and connected through my PC?
Well, that would depend on the audio capabilites of your PC.
Once you figure out the software controls of the PC audio you can treat the PC like any standard audio device for input or output if the compatible physical connections are there.
Mar 03, 2011 | Panasonic SC-HT900 System
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*PAL system discs
8DIVX Video Disc
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
Disc tray won't open
try turning the dvd off if this dosn't work than try rotating the tray , there maybe a cd jammed in the unit . If this is the case you will have to remove the cover and manually remove the cd.
Jan 31, 2009 | Panasonic SC-HT730 System
I kept hitting the disc exhange/eject button to turn the unit on and after a couple of tries it finally opened about half way. The whole reason i wanted to open it was to get the last dvd that i watch out of it. Well in doing so i noticed that there were some discs rattling around up underneath the cd tray (from my 1 1/2 year old). After shaking the unit a couple of times i was able to get the discs out of the underside of the disc tray. When i hit the disc exchange to close the try the unit powered up, closed the tray, and operated fine and i am back to using it like i used to with out any other problems.
Oct 15, 2008 | Panasonic SC-HT940 System
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Bose 321
To get my unit open I hit on/off and the source button at the same time. Then open showed up on the 3-2-1 window, then I hit the eject button. It works fine now.
May 07, 2008 | Bose 3·2·1 II System
Panasonic SA-HT700 Home Theatre - Tray won't open
i have the same issues. Just took a screw driver to the four sides and opened it up. Took 5 mintues. Pulled them out.
Dec 30, 2007 | Home Theater Systems
Sound Clicks Off
let a tech check your set for safety he will be able to tell you what is the problem.good luck.
Apr 16, 2007 | Panasonic SC-HT700 System
Panasonic SC-HT680 System Logo
57 people viewed this question
Top Panasonic Home Theater Systems Experts
Richard Roth
Richard Roth
Electro Med Services...
Are you a Panasonic Home Theater System Expert? Answer questions, earn points and help others
