Question about Casio Cassiopeia E-125 Pocket PC
Screen goes out periodically
During use the screen will go dark, the unit is still on and seems to function correctly.  If you jolt the unit the screen comes back on.
  • 4 Answers
Screen went into sleep mode. you can set the time in system manu some where.
Posted on Jan 01, 2008
Screen goes dark at random times
Usually caused by 1 of 3 issues:
1. Backlight in screen failing
2. Inverter board failing
3. Loose connectors or cracked wires from motherboard to screen.
To rule out other motherboard related issues, connect an external monitor and see if it functions properly.
Replacing a laptop screen is usually fairly easy - and instructions can be found easily on the internet. Use care, and don't force parts apart. Taking your time and exercising considerable patience will bring a successful repair.
Instructions, and parts, can be found easily on the Internet by searching for "<my laptop make and model> screen replacement".
If you're not comfortable doing this yourself, numerous local computer repair shops provide this service - or you can send the computer to repair services available on the Internet.
Dec 30, 2012 | Computers & Internet
We have a Mitsubishi sd200u projector.The right side of the screen is dark,there is still picture but very dark.We thought it was the bulb,ordered and replaced that,and we are still having the same...
Does the dark side have a well defined straight vertical edge or is it ragged and blurry.
Is the picture still visible in the dark area, or has the picture disppeared and there's this darkness that has taken over.
I'm thinking that the optics may have been jolted. Has the unit suffered any impact or the like.
Mar 19, 2011 | Mitsubishi SD200U Multimedia Projector
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Our monitor just recently stop working correct. It is on fine during boot but once Windows starts up, the screen goes dark after about 2 seconds. If you turn it off and back on, we get a screen again for...
try reinstalling the os.
there might be file corrupted in the system folder,,,
since the monitor runs on start up , we cannot say that it has a hardware defect...
reinstalling or upgrading your windows will help..
Mar 11, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
My LG RE-44SZ21RD tv goes off spontaneously. will come on after a long period switched off but go off again. no rhyme or reason to the issue. i thought it was some sort of software issue because just befor...
this problem seems to have corrected itself although the dark patch at the top of the set is still present.
I cannot think of anything in particular that i may have done to fix it but i have resorted to turning the TV off using the on/off switch after using the remote. Other than that i removed/replaced the bulb.
so far, it is 3 weeks and counting since i last had any problems.
Dec 19, 2009 | LG RE-44SZ21RD 44" Analog Television
Can't figure out how to restore the screen
goto control panels then to personalize then monitor settings or display setting and change it there.hope that helps
Nov 25, 2009 | Dell Inspiron E1405 Notebook
After working normally for several years, my Inspiron 1100 display went dark but will come on normally if I press Fn+CRT/LCD BUT ONLY FOR 1 OR 2 SECONDS then goes dark again. Tried holding F8 during...
there is a ribbon cable going from the lower [keyboard unit] to the upper unit [display] that has been going bad over time. or the display panel backlight is bad.. you might be able to save old betsy by taking her to a laptop shop and see what they can do..goodday
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Screen problem Hp dv1000
The main two causes for this, are the inverter, which supplies the screen with the proper amount of power in order to function correctly, or the screen. If the inverter isn't puting out enough power it will cause the screen to darken or black out completely. Start by checking the screen connections. If all the connection are properly seated, the it's either the inverter or the screen it self.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
