Question about Dryers
Amana LGA30AL Dryer - does not dry cloths completely in the same amount of time it used to take. Vent system is clear, flame comes on within seconds of igniter glow but doesn't appear to stay on very long. After some time it will repeat this cycle.
    Sergeant:
    Champion:
  • 226 Answers
Most times this is due to a lint backup some where in the shaft leading out of the house.ecpecialy ifit vents out verticaly.you can use a compressor with a blowgun in most cases to solve this.
Posted on Jun 04, 2009
Clothes come out of my gas dryer with a slight chemical smell
In my years of experience, the only situation like this resulted when painting had been done within the last 12 months. The flame burns off the VOCs. Beyond that, it's a stumper.
Apr 20, 2014 | Maytag MDG2706A Gas Dryer
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Amana gas dryer not hot enough. Flame is too small.
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jun 10, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Clothes not drying properly
Consider a blocked air flow/vent problem or bad gas valve selonoids. Important to check outside vent door if present to make sure it is opening all the way. If not the dryer goes off on thermal overload. If vent is clear consider selonoids located on top of gas valve held in place with 2 philip head screws. One has a two prong electrical plug and the other has a three. Last check Lp tank for gas. Thank you
Jun 01, 2009 | Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Very long drying time
ck vent system if vent not oper it can cause flame roll out and shut off unit also ckd flame sensor on side of burner
Jun 01, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
