Question about HTC Touch Pro Smartphone
Keyboard doesn't work
When the problem began, there would be a delay and sometimes repeating characters. Now, the keyboard doesn't respond at all--despite lighting up when I slide it open.
    President:
  • HTC Master
  • 762 Answers
Did you tried soft reset? Which ROM version you have? Go to HTC.com and check if there's an ROM update.
Posted on Jun 04, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How to fix sticky keys
    You must increase the leadtime before Windows considers your keeping a key pressed down means you want to repeat it.
    Open Keyboard Properties by clicking the Start button , and then clicking Control Panel. In the search box, type keyboard, and then click Keyboard.
    Under Character repeat, move the Repeat delay slider to the right to increase how long you must hold down a key before the keyboard character repeats, and then click OK.
    Jul 24, 2014 | HP Pavilion Computers & Internet
    Keyboard mistyping issues
    1. Change to United States-International keyboard layout.
    Manually change to United States-International keyboard layout
    2. Use the Microsoft Fix it 50558
    3. Confirm if the Keyboard is wired or Wireless
    Information:
    Ensure that batteries are new for the wireless keyboards as drained batteries can
    cause delay.
    Slow computer can also cause the issue. Check if computer is slow and perform necessary troubleshooting steps related to performance after following below provided troubleshooting steps
    Steps:
    Clear Turn on Filter Keys, or adjust the settings to a quicker rate for Windows Vista and Windows 7
    Clear the Use Filter keys check box, and then click OK for XP
    adjust your keyboard's repeat delay and rate settings
    Drag the Repeat delay: slider to Short
    Drag the Repeat rate: slider to Fast
    Click OK.
    Close all windows
    Is issue persists, Reinstall the Drivers
    Follow below steps :
    http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
    Mar 22, 2014 | Dell Inspiron 1525 Laptop
    Keyboard
    Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
    Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
    Feb 04, 2013 | Vizio Silver 15.6" Thin Light CT15-A2...
    Keyboard typing multiple letters/ numbers when pressing certain keys.
    Feb 03, 2013 | Computers & Internet
    My keyboard typing multiple letters
    Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard\'s repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
    If fails
    Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean
    If you are still feeling industrious, next you can tackle cleaning your mouse Of course, if cleaning your keyboard seems a truly undesirable task, you can always buy one for around $20.
    Hope this helps.
    Dec 31, 2012 | HP Computers & Internet
    When typing I can see letters with 3sec delay on the screen
    This is not keyboard issue
    if you are using windows xp , do the following
    goto RUN
    type %TEMP% enter
    and delete all files, then restart computer
    then you can check
    thank you
    Jun 30, 2011 | Compaq Keyboard
    My keyboard is inserting additional characters when I type, what can i do?
    Try this steps:
    1. goto start ' control panel
    2. select printer and other hardware
    3. select keyboard
    4. one new widow will open..
      adjust repeat delay and repeat rate..
    5. if you are satisfy click ok.
    Pls rate it if you it helps you. thank you.
    Oct 10, 2010 | Gateway 2520915 Keyboard
    Keyboard is too sensitive - getting multiple characters
    I too have encountered this problem. It was the q key on a dell latitude d530. After reading a post on an osxforum describing a software issue i attempted to fix the problem by adjusting the sensitivity of the keyboard. This did nothing. Next i attempted to determine if there was a physical issue. I popped the key off and discovered nothing. I also popped out the white plastic 'scissors' that the key fixes too and still discovered nothing. I looked under the rubber... nothing. compared it to another key... nothing. All in all I could find nothing abnormal about this key other than the fact that it was super sensitive. so I began to experiment. I put a piece of paper under the rubber. This made the sensitivity just about perfect so I left the little bit of paper in place, reassembled, and have had no further problems. This is ghetto i know but it worked for me...
    Nov 19, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
    Keyboard responds time
    To adjust the key repeat rate
    1. Open shortcutcold.gifKeyboard in Control Panel.
    2. On the Speed tab, make changes as follows:
      • To adjust the amount of time that elapses before characters repeat when you hold down a key, drag the Repeat delay slider.
      • To adjust how quickly characters repeat when you hold down a key, drag the Repeat rate slider.
    note.gif Note
    • To open Keyboard, click Start, click Control Panel, click Printers and Other Hardware, and then click Keyboard.
    Good luck and please rate me
    May 02, 2008 | Computers & Internet
    HTC Touch Pro Smartphone Logo
    408 people viewed this question
    Top HTC Cell Phones Experts
    Ashutosh Khandelwal
    Level 1 Expert
    D. E. Hev
    Tech Leprechaun
    Tech Leprechaun
    Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
