Question about Zapf Baby Annabell 4-Poster Crib
I have the same problem too.
I have tried replacing the batteries with new ones and still the baby wont work. any ideas?
My Graco baby swing isnt swinging, brand new batteries in it, its brand new..
Because it is brand new it isn't a good idea to do any tinkering or the warranty will be invalid.
I suggest as a first step to read the instruction leaflet thoroughly for any helpful troubleshooting guide or in case you missed an important instruction.
It is wise not to assume the batteries are ok even though they are new. Batteries aren't always treated well by those who transport or sell them and sometimes a battery will be rendered useless by dropping it or handling it roughly.
I suggest you clean the battery contacts with a solvent in case a wax corrosion inhibitor had been applied and then use a battery tester or another battery-powered appliance to ensure each cell is working correctly.
If each cell tests good refit them ensuring each is fitted the correct way around and after fitting the battery cover switch the swing on. If it still doesn't work find the seller's receipt and return it to the shop for exchange under the guarantee.
I strongly suggest you attend to these things when your baby is sleeping and you are properly awake and without an audience or distractions or trying to watch tv at the same time.
Feb 02, 2015 | Graco Six Speed
06 ford falcon wont do nothing wont start or turn over new bat
Bad or loose battery cable(s). Tighten the connectors on all ends, and go hand-over-hand to inspect them for fault or damage.
Just enough juice to make the radio work but not enough to turn it over, right?
Try this test: Turn the headlights on, then try to start it. If the headlights (or interior lights) dim down or go out, then if it ain't the battery, it surely is one of the vables or connectors.
Jul 20, 2014 | First Years The Red Stripe Ingnite...
89 jeep cherokee wont start
after replacing your ignition coil, try replacing also your high tension wires.
if this does not solve your problem, try using another battery (preferably a larger one), might as well be a weak battery
May 18, 2012 | 1989 Jeep Cherokee
Put new batteries in the bouncin baby alive and it only works for a second AND only on the try me switch, not the ON switch. Batteries are in correctly
Got the Black one and have the same problem..in try me it worked fine now it wont do anything...I wonder if the white ones work? LOL
Dec 25, 2010 | Hasbro Baby Alive Bouncin Babbles Baby...
Our Robert Shaw thermostat 9520 just went blank. Do you have any ideas, nothing is working?
Try replacing the batteries.
Remove the cover by using a coin or screwdriver to prise it off. Insert the coin at the left side between the backing plate and the the cover, and twist.
Romove old batteries and insert new ones.
Mar 06, 2010 | Shaw Robert RS-9420 Thermostat
Why wont baby annabell close her eyes
it must be a defect in the doll. you should either return it if possible or replace it.
Jul 27, 2009 | Zapf Baby Annabell 4-Poster Crib
Replacement seat for dj seventy baby walker
I would try contacting Chicco directly, or a local stockist of Chicco products. They should be able to get one shipped to you. I wouldn't have any idea of how much this would cost though!
Apr 01, 2009 | Baby Gear
Furby won't work
Have you tried restarting? It's different from resetting. You have to keep his tongue down (as if you're feeding him) while resetting. This worked for me when Furby didn't move, only made sound. Good luck! (If you still have it, it's May already)
Mar 03, 2009 | Hasbro Interactive Furby for Windows
Battery Problems
Have you tried a new set of batteries?
Oct 06, 2006 | Canon PowerShot A80 Digital Camera
Zapf Baby Annabell 4-Poster Crib Logo
Top Zapf Baby Gear Experts
Dorel UK
Dorel UK
JonSnell Electronic
JonSnell Electronic
Are you a Zapf Baby Gear Expert? Answer questions, earn points and help others
