Question about Ricoh 3310LE Copier
Toner light does not go out after adding toner
  • 541 Answers
If the lid from the old bottle stays in the toner slide you new bottle will never open when the handle is pushed down. if this is not he case. does the machine make a banging or grinding noise? i f so you gears in the pcu are bad and no new toner is being fed to the toner sensor. you toner motor could also be bad. you must check to see if your old lid was removed first.
Posted on Oct 11, 2009
Are you sure that the "plunger" located in the top of the toner bottle did not remain in the machine from the previous bottle? Sometimes it is not fully released when it is removed, and then it obstructs the flow from the next bottle. Remove the new cartridge, and look into the front of the toner hopper. All you should see are the "claws" that grab the bottle when it is inserted into the machine. If the "plunger" is in there remove it. Please let me know :)
Posted on Jun 04, 2009
Ricoh mP 2018D Giving " adding toner "message always
that what it does to let you know that its adding toner
Apr 04, 2015 | Ricoh Office Equipment & Supplies
Toner not added automatically ,i add toner manually,print become dark
press 0 & 5 simmilutely m/c. on type 200 press start m/c. is moving you see screen when figure is going 230 to 245 then press enter then press intruppt hope your m/c. ready
Feb 24, 2014 | Toshiba estudio 305 Copier
Brand new on power up attention light continually flashes and message says Please wait (Adding toner) and stays there forever
It is normal to do this "adding toner" operation aprox. 20 minutes. You have to wait until the printer enters in "ready" status. Take a little brake and relax, your printer needs to fill/refill the developer unit with toner dust from the cartridge.
Feb 16, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
I have changed the toner in my printer and the toner light continues to stay on/won't print. I tried changing the drum and still the toner light stays on/won't print. I tried opening the toner door and...
No guarantee this will work but I refilled toner on my Brother 5170 and it only worked after making sure the old stuff was completely out. After removing the little plastic plug, I tapped out the toner repeatedly on the side of a trash can (like 50 times) then took a shop vac and let that **** out whatever toner was left. It really seems to be important for some reason to rid the cartridge of ALL old toner before adding the new stuff. Hope this helps!
Feb 23, 2009 | Brother HL-2040 Laser Printer
Add toner is display on screen and phtocopier doesnot work
Some copiers have a switch that comes on when toner is low to get the light to go out you must ad toner In some cases the copier will not print until you add the toner
FIX
open front door there is usually a diagram that shows where to ad toner
Jan 06, 2009 | Panasonic DP-8045 Grayscale Copier
Low toner
Toner fully try in Developer unit wait same time for toner adding and press start contuies 10 copies it will slove the problem.or clean toner level sensor
Jul 24, 2008 | Toshiba e-Studio65 Copier
Toner light will not go off
Did you remove the tape from the toner bottle when you installed it? It may just be looking to add toner back to the developer, to bring it back to the set level of toner? See if it stops
Apr 28, 2008 | Office Equipment & Supplies
Error light on and toner low/ replace drum light on
I was talking to dell and they said it was because of my toner. Guess I will try a new dell toner.
Feb 21, 2008 | Dell 1710 Laser Printer
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Ricoh 3310LE Copier Logo
80 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
