Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Dishwasher fills cycle runs for a few seconds and then it stops and motor growls
No matter what cycle I choose, I start up the dishwasher it fills as normal and starts to wash like it should.  After a few seconds, you can hear that the water no longer is being forced and the motor growls until you actually shut it off.  I am very disgusted as this dishwasher is only 2 years old and for what I paid I am very dissatisfied and looking for any solutions anyone may have
    Problem Solver:
  • 6 Answers
Check for a deformed shaft on the water level float. Remove the kick plate and look for where the shaft of the float touches a micro switch. Often the shaft is bent sideways and only engaging the micro switch indirectly. Straighten by hand for a temporary fix or reinforce the shaft with aluminum tape and sewing needle. Keep the retrofit light weight to avoid problems with water overflow.
Its also possible you may have debris clogging the check valve that keeps water in the tub during certain cycles. To find the checl valve you'll need to remove the lower rack and completely disassemble the central assembly from the top down. If you are mechanicaly inclined its not hard. If you are worried about proper re-assembly, then video tape the disassembly as a memory aid and stack the parts and screws in careful succession.
Once you reach the steel garburator blade you only have one more plastic plate to remove. Examine both ports on the plate to ensure that there is no jam or debris. Throughout the disassembly, look for any broken glass or debris that could be jamming or clogging.
If neither of the above problems is found then the other possibility is a deflective or melted down circuit board. Check your owner's manual for longer warrantees on the control panel. A long time ago they use to have 3 - 5 year warranty. More recently the warrantees have been only for one year. Check your owner’s manual because if you ask the call centre they will always say one year even if the warrantee is longer. If the part is covered then disassemble the door to get at the control panel. Look for signs of melting/overheating. If the unit is out of warrantee then replace the dishwasher. The control panels cost as much as the dishwasher. Replace your Maytag with a quality brand like Miele. Avoid, Maytag, Jennair, Kitchen Aid, Whirlpool, Kenmore, White Westinghouse. They are all made by the same umbrella company with the same crappy parts, poor reliability, poor cleaning results and short term warrantees.
Use to be you could get 10 – 20 years of service from a North American brand. These days 3 – six months of clean dishes as much as many customers can expect before dishes become progressively more and more disgusting. Poor engineering is responsible because the designs are prone to jams, clogs, water level malfunctions and circuit board failures.
Posted on Jan 27, 2009
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
wait a few seconds
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
433 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
