Question about Denon Televison & Video
Denon DVD player - model DVD-5910CI I am using (1) HDMI cable for video direct to my HDTV and (6) interconnect cable from 5.1 channel audio outs to my surround sound receiver. The issue we can't figure out is that we cannot even select multi-channel on the "setup" screen. It is greyed out. I can only choose SACd filter or compression. We cannot figure out how to get multi-channel to play. I do not see how anything could be wrong. When I use the remote and go to "start-up" then "audio" I am only able to select "compression" or "SACD filter". Please help as I can only hear stereo with SACDs, DVD-As, music DVDs.
  • 315 Answers
You have to go into your 'HDMI' audio settings tab, and select "2 Channel".
Once you have selected "2 Channel", then when you go into the 'Audio Setup' tab (different tab then the HDMI audio tab), then they will no longer be greyed out. You can then change it to Multi Channel and they will now all work. I had this problem too, when I first got my 2910. If you are using HDMI for watching Movies etc, then you will need to put the HDMI audio setting back to Multi ...when you are done using your Multi Channel analog outputs
Posted on Jun 04, 2009
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Televison & Video Logo
54 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
