Question about Sharp AL 1631 Copier
Sharp SF 2014 copier power problem
I have a sharp SF 2014 copier AND it's not getting any power.
please what should i do?
  • 313 Answers
Also you could check to make sure the doors and side door sensor is working as these control power inputy also
Posted on Jun 11, 2009
  • 52 Answers
Check the power cable for power. If there is power at the end of the cable but the machine does no switch on,the problem might be with the power supply. If there is a fuse which is user accessible, check that. Otherwise its a technician job.
Posted on Jun 04, 2009
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
Sharp sf 2014 copier problem
clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Jun 04, 2009 | Sharp Office Equipment & Supplies
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
Apr 02, 2009 | Sharp SF 2020 Copier
Melted exit rollers SF 2020 Sharp copier
Please.....do yourself a favor, and call a service tech.
Feb 27, 2009 | Sharp SF 2020 Copier
On a sharp SF-2020.. I get a U5 code with 01 subcode...
u5 indicates the ADF can't communicate, make sure the ADF is pluged into the copier. MAKE SURE TO UNPLUG COPIER BEFORE CKECKING ADF PLUG. If all is good then main board is bad.
Feb 25, 2009 | Sharp SF 2020 Copier
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
Sharp SF-2014 Copier Jams
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Aug 20, 2008 | Sharp Office Equipment & Supplies
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
