Swintec 7040 Typewriter Logo
Posted on Jun 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a swintec 600 typewriter is just started beeping when you turn it on it moves to the left margin and begins beeping the buttons wont do anything
Dick O Reilly
Level 3:
  • Swintec Master 3,594 Answers
  • Posted on Jun 11, 2009
Dick  O Reilly
Swintec Master
Level 3:
Answers
3594
Questions
Helped
609619
Points
6852
Check to be sure the printwheel is properly installed. DickyO
How can i set the margins on my Swintec 1000 typewriter?
move carrier to the new position for the margin press
left mar button, do the same for right side except press the right margin button
2answers
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
My Swintec 7000 typewriter will only go half way over and beeps. It wont let me go any further unless I start a new line HELP!
The R. margin is probably set there. Go to the stopping point, press but don't hold the mar rel key, space to desired location, press R. mar key.
DickyO
When I turn on the Swintec 600 it will go to the far left side, but when you hit the return button, it will not return to the left side, but stops in the middle.
If it dosen't make a growling sound th L. margin is probably set there. Go to that point touch but don't hold thr MAR REL key, backspace to desired location, press L. mar. key. If it growls put a little WD40 on the silver shaft that the carrier slide on.
DickyO
I would like to set the right margin. It keeps beeping and wont move.
Go to the R. margin press but don't hold the mar rel key space to where you want the margin, press R. mar key.
DickyO
4helpful
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
When i turn it on it will beep every letter i enter but won't type anything it is a swintec model-600
try putting the machine in test mode. You can do this by holding down the margin release key while turning it on. Keep holding it down until it starts typing by itself. Then turn it off and on again and see if it works.
Working with automatic centering feature
set both the left and right margins where you want them and starting withe the carrier at the left margin turn on the auto center then type, when you then hit the return button it will type centred between margins
2helpful
Swintec 2000 Margin
You should reset the margins where you would like them. To do this, go the the file screen and press MARGIN. Press <--- to change the left margin, or ---> to change the right margin, or the up arrow to change the top margin, or the down arrow to change the bottom margin.
Do one at a time. When you choose one (i.e. <---), the message "LEFT MARGIN SETTING" appears on the screen and the cursor moves to the left margin column automatically. Move the cursor to the desired location by using the arrow keys. As you move the cursor, the corresponding margin mark moves along with it. The press "DO" to set the new margin.
Hope this helps.
Jay @ www.granadahillsbusinessmachines.com
2answers
Margins
Position the carrier wher you want the margins by the space bar or back space and touch the left margin or right margin key button as needed
Top Swintec Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Mitch Vass
Mitch Vass
ADMIN Andrew
ADMIN Andrew
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
