Question about Sony Car Audio & Video
My radio,clock,horn wont work are these all connected
  • 87 Answers
Sounds like its just a fuse, check the main fuse box either under the hood or in the passenger compartment.
Posted on Jun 04, 2009
My horn won't work on my 2007 Uplander. Checked fuses, and wiring and everything is fine. What could it be?
This is caused by a loss of connection in the coiled ribbon contact under the steering wheel called the Clock Spring contact. Before you remove the steering wheel to replace this contact drum you MUST DISARM the Airbag system. Failure to disarm the system can result in serious injury or in rare cases *****.
May 12, 2017 | Cars & Trucks
MY LOW BEAM LIGHTS, BREAK LIGHTS AND RADIO SOUND CONTROL ON STEERING WHEEL, ALL STOPPED WOKING
Steering wheel radio controls and horn not working - Jeep Wrangler ...
www.wranglerforum.com/.../steering-wheel-radio-controls-and-horn-not...
Sep 22, 2014 - 12 posts - ‎6 authors
... 2Dr sport and my step/reset buttons, radio control and horn all stopped working. ... Also the lights behind the step/reset and cruise control went out, but the ... Soundslike a bad clock spring ribbon cable in the steering wheel. steering wheel buttons not working
Jun 14, 2012
Steering wheel audio controls
Mar 5, 2011
More results from www.wranglerforum.com
Nov 23, 2015 | Cars & Trucks
2009 Hyundai Accent My horn and radio doesn't work. I've checked the dash fuses and relays under the hood, I need help please!
The radio doesn't from the buttons on the steering wheel ? The clock spring inside the steering column could have an open in the wiring ! The clock spring allows you to turn the wheel from full left to full right while keeping the horn an radio control buttons connected electrically with wires going down the steering column . Do you have a Air bag light lit on the dash ? How cars clock spring works
Sep 26, 2015 | Hyundai Cars & Trucks
Horn wont stop 1994 integra
Check the clock spring located inside the steering wheel. That controls the radio.
Mar 31, 2014 | 1994 Acura Integra
99 Acura RL 3.5 horn does not work
You have a defective part called a clock spring contact under the steering wheel, this contact is a coiled up simi rigid plastic ribbon with circuits embedded in it, after many years they l break and you loose the connection from the steering wheel controls (radio) and the Airbag. You must disarm the airbag on the steering wheel and remove it and replace the clock spring contact drum under the wheel, the cost is about $300.00
Jun 07, 2012 | Acura Cars & Trucks
Horn wont work when I put new horn on
Hi
Either
Poor earth connection to the horn or to/from the horn switch.
The horn switch has failed, loose wires or metal strip dislodged, wires can come free on steering wheel centre horns. finally the fuse for the horn, often is a shared fuse with the radio or dashlights
Regards
Dan
Dec 31, 2010 | 1998 Isuzu Rodeo
The a/c power wont work. Tried several different
check the power plug used to connect the clock radio to the mains power,if it does not come on.then you have to open the back cover of the clock radio to check for blown fuses, because this are the common problem found in electronics appliances.
Also check the transformer with the use of an ohmmeter, to read if the components are okay.
Good luck.....
May 25, 2010 | Grundig G2000A Clock Radio
Havin 04 cavalier problem....
Double check the fuses. Also, there are usually TWO fuses for the radio. One has power when the car switch is OFF. This keeps the clock working and your radio presets set. The other is when you turn the key on. The horn not working can be tested if you have a 12V test light (Wal*Mart sells them...). Unplug the horn, hook up the test light, press the horn button. If the light glows, you've got a bad horn (go to your local junkyard for one). If not, recheck ALL the fuses. Good Luck
Mar 11, 2010 | 2004 Chevrolet Cavalier
Horn wont blow
the problem is the rotating contact that connects the horn to the steering column wiring harness, this part is called the clock-spring contact, u must remove the steering wheel to change the part out.
Dec 15, 2008 | 1999 Cadillac DeVille
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
