Question about Ulead Videostudio 8 for PC
"cannot initialize application Screen
"cannot initialize application Screen resolution is too low" is the message. It worked right after installation but did not work after that. Keeps giving the same message. tried the compatiblity mode. Increased screen resolution to 1280 X 780.No help. Restart done. but to no avail
  • 700 Answers
Try to increase its resolution next to 800X600 or this version maybe works at this settings, version 9 needs 1280X800. Try to adjust the resolution first before you run the application. Or check your driver. Or reinstall ulead with the resolution set to 1280X800.
Hope this gets it working.
Posted on Jun 04, 2009
  • fougzki Jun 06, 2009
    On my unit it say at least 1024 X768. that's UleadV9.
PC - TV Screen solution issues.
the resolution of your monitor is not working on your tv. Try changing the screen resolution to a different size. Right click on the desktop and choose display settings. change to either a lower or higher setting . you can work from low to high until the tv works.
Jun 15, 2013 | Philips 32PFL3505D 32 in LCD TV
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
The monitor keeps going blank with a message ''no signal'' or ''out of range''.
Probably you are out of the resolution range for this monitor. Try to boot you computer in safe mode (for low resolution) using F8 just before the windows start screen, step down the resolution, restart and try step by step to upgrade the screen resolution.
Stelios.
Feb 21, 2010 | Computers & Internet
Can't click Accept in Software License Agreement dialog box in Ad
This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
May 17, 2009 | Adobe Acrobat 7.0 Professional
Blackberry device error 411. I also had a strange
Before Perfoming these steps take a Back up of your Handset. Cause 1 The wireless transceiver software was not loaded onto the BlackBerry device correctly. Resolution Re-install the BlackBerry Device Software using BlackBerry Application Loader. Connect the BlackBerry device to your computer. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next. If prompted, enter your BlackBerry device password and clickNext. The Application Loader Wizard examines your BlackBerry device?s current configuration. When it is finished, the Application Selection window appears. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears. Do not click Finish. Click Advanced to begin loading the applications. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete. Click Finish to begin the BlackBerry Application Loader process. Click Close when the loading operation is complete. Cause 2 There is a wireless transceiver hardware failure. Resolution Contact your service provider for more information.
Mar 24, 2009 | RIM BlackBerry 7290 Smartphone
Hi i want to widen my screen
The Resolution can be changed in Windows XP by minimizing all applications, right clicking on the desktop, selecting Properties. In the Display Settings window go to the Settings tab. Here you can change the resolution. I think you are wanting to use a widescreen setup so going for a resolution of 1280x800 should fill your screen. Play around with the available settings to resize the screen.
If you are using MS Vista, you need to minimize all applications to the desktop, right click, select Personalize. In the Personalize Window click on Display Settings down the bottom, modify the resolution as appropriate.
Alternatively, you may be able to find the function key that did this to your resolution. Above your F1-F12 keys there should be a little picture. If you click on the [fn] key (near the Windows key) as well as one of the F1-F12 keys you can cause different functions to be performed. This may be how the resolution changed initially.
Good luck
Apr 23, 2008 | Toshiba Satellite A35-S159 Notebook
Trying to connect laptop to plasma tv model number 42PF9945. keeps displaying picture format not supported. using vga to vga on tv.
To my knowledge your Philips 42PF9945 is capable of a maximum of 852 x 480screen resolution at 50Hz. It is TV standard but pretty low for PC work, that being the case, perhaps what is required is for you to lower the Screen Resolution as well as the Screen refresh Rate of the laptop. They may be found in the display properties (Control Panel) or right click on any clear area of your desktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Text to small when printed out
may be your screen resolution is too low (things on the screen appear as big). Try increasing your screen resolution.
To do this. Right-click an empty area of desktop > click properties > Click setting > move the slider of the resolution tab towards the higher number.
Sometimes the application that is used to create or print the document may be set to a view level of low zoom size. increasing the resolution view size of the application should solve your problem.
It is recommended to use true type fonts they print in actual size.
Oct 27, 2007 | HP PSC 1350 All-In-One Thermal Printer
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Ulead Videostudio 8 for PC Logo
1,176 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
