I have formated hard disk. Give me software for sound and Lan
  • Fardin Ahmed
    Fardin Ahmed May 11, 2010
    What motherboard make and model r u using?
Driver detective software will get you the drivers you need, download a copy from http://www.fixyourdrivers.com
hope that helps
Posted on Jun 04, 2009
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
How can i format my laptop
Step 2
Step 3
Step 4
Step 5
Step 6
May 06, 2010 | Computers & Internet
My octave copy master has a hard disk problem. if i reformat, do i need a disk to format?
Ok, first, "reformat" means you have done a format before, **** your question (about the format disk), explains that you havint?
..so have you?
OK, second, if you have a hard disk problem, you must to know what is the problem first, to solve it. (the solution might be a lot easier than it appears)
THE problem might be, a phisical problem , where your here sound comming from the disk, or a hardware/software problem, were your disk Master Boot Record (MBR) is damaged , this can cause booting problems, and even alot more.
SO u need to locate the problem, when doing this, you will find a lot of solutions, and alternatives for solving your problem....
CHECK if your hard disk is beeing recognised at startup, or in bios.
if it is, then problem one, can be bypassed, and you can continue to the next problem were you have alot of solutions.
Well this is not a solution for your problem since the discription is not enough to identify it, **** i think this can give an idea and a basic knowleg on whats MIGHT be going on.
and Finally, yes you do need a format tool, the simplest way is to insert the setup disk of any operating system (beside linux if your not familiar with it), and format it, i recomend the windows xp setup disk its the easier!
gd luck and lett me know what have you done.
Jan 01, 2010 | Octave Copy Master II Burner
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
No speakers
Download and install the speaker drivers from the manufacturers website. Click on the support link, lookup your specific model # and select the operating system you are running. Once installed reboot and you should be all set. Hope this helps.
Aug 19, 2009 | Philips DGX320 Computer Speakers
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
The Motherboard refuses to allow for Hard disk formatting
Hi , Because the 1st boot option should be Hard Disk in the BIOS save and exit and then boot
Mar 22, 2009 | Computers & Internet
My desk top hv no sound
ur motherboard has a disk containing the drivers needed for components like the vga card.. sound card (if integrated onto the motherboard), local area network (LAN) etc..to work.. this disk probably came along with ur computer.. unfortunately.. when you formatted th hard drive and reinstalled windows u got rid of all these drivers and they must be re-installed in order for these components to work..
if there is no disk present you can download drivers straight from the manufacturers website by typing in th make and model name of the sound card..or of the motherboard if p.c has a soundcard integrated onto the motherboard) into the address bar (the bar at the top normally..this begins with http://) you can find these details by going to start > all progs > system tools > system information > components > sound.. this will display the name and model etc of th card.. once on the manufacturers website there is usually a link for downloads to follow..
alternatively go to start > control panel > system > hardware > open "device manager" > once open look in the list for any yellow explanation marks anywhere..right click on any item showing this and delete..then restart the pc.. once it has restarted th pc will automatically detect new hardware and look for drivers.. often the best move now would be to rollback the drivers when given the option but this wont work after a disk format because th format clears th hard drive of everything..including updates and drivers so.. if you DO have a disk supplied with your pc carrying the required drivers (most new pc's will have this supplied with several other disks required to install software or applications...... this is far the easiest method of installing drivers
Nov 23, 2008 | Trust Ever 32bit 4-Channel PCI Sound Card...
Hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Oct 10, 2007 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
