Question about Whirlpool RBS275PD Electric Single Oven
I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
I have a whirlpool oven model no. G2P61/01SR/WH. The oven is not heating up. The fan works fine and so does the grill.
Thanks
  • 374 Answers
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
Oven not heating but fan working
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 05, 2011 | Whirlpool Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Oven not heating up
If it is a fan assisisted oven, and the fan is working o/k, then it is pronably a faulty fan oven element that is faulty.
Mar 29, 2010 | Whirlpool RBS275PD Electric Single Oven
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
I have a whirlpool oven Model G2P61F/01SR/WH AND IT DOES NOT HEAT UP. i AM GUESSING ITS THE ELEMENT IS OPEN CIRCUIT BUT CANNOT FIND A SCHEMATIC TO LOCATE IT AND CHECK. CAN YOU TELL ME WHERE THE ELEMENT IS...
If it is an electric fan assisted oven, then the element will be located at the rear of the oven compartment, behind a removeable cover.
Hope this helps you.
Jan 09, 2010 | Ovens
My whirlpool fan assisted oven is not heating the fan is blowing cold air out, my gril and my hobs work fine
Sounds like you need a new fan element. You'll need to quote your model to ensure you get the correct element. A lot of Whirlpools can be done from the inside so the oven stays in the housing. Don't forget to power off first though! :)
Jun 21, 2009 | Ovens
No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Apr 12, 2009 | Ovens
Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Sep 27, 2006 | Whirlpool GBS277PD Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
694 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
