Question about Fellowes Manufacturing Powershred C-480C Shredder
Full bin light is always on!
Where is full bin sensor???
  • 3 Answers
On most shredders the full bin sensor is actuated with a plate just under the cutter head. When the bin gets full the paper builds up and pushes the plate back.
Be sure to unplug main power before during any service.
Try wiggling the plate back and forth to clear out any backed up paper.
Posted on Jun 04, 2009
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
Jan 16, 2014 | Scotsman Cooled Modular Contour Cuber...
Bin full light
The sensor build limestone residue during operation and needs to be cleaned off. The bin sensors are typically located on either side of the freeze platens and can be removed to clean. Turn machine off and unplug. Reach in past the water trough and freeze platen and you will see the transmiter and receiver plugged into the side walls. Gentlely work sensor loose and work sensor wiring out hole until you can get to sensors. Clean the two sensor with a clean cloth and with vinegar until sensers are clean. Reinstall, and plug back in and start unit. Bin sensor light should be out and should start.
Aug 24, 2013 | Scotsman Refrigerators
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Model C-480C, always says bin is full! Where is the sensor?
Look up under the cutter asm and remove the paper shreds that are stuck in the blade assembly.Also clean the sensors with air or cotton swab.
Jun 03, 2009 | Fellowes Manufacturing C420 (Strip-Cut)...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Mar 26, 2009 | Fellowes Office Equipment & Supplies
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Fellowes Manufacturing Powershred  C-480C Shredder Logo
1,456 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
