Question about HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop
My computer will boot up and then then screen will go blank but the computer is still on. What is wrong with my computer?
  • 1,006 Answers
Either u have a problem with WGA or monitor..Try to put another wga AND if still have a problem ur monitor need to reapir
Posted on Oct 24, 2007
WANT TO UPGRADE FIRMWARE. SCREEN GOES BLANK
Allways read about the serial number before flashing firmware or the wrong firmware revision was loaded for this model ?
firmware chip replace by new or lend a chip with an appropriate revision start and create a hot-swap by reinserting the old chip and re-flash the correct firmware in it, because he will likely continue to boot black
Feb 25, 2016 | Samsung 2232GW
My itellipad only shows a blank screen and won't allow me to do anything. What's wrong with it and how do I fix it?
Looks like your OS is stuck in a loop and will need a hard boot. you can hard boot the computer. but this issue is usually caused due to corrupt services, i recommend getting a technician.
call 1-877-805-1027 for expert help
Nov 18, 2015 | Computers & Internet
What do you do when you get a blank screen?
1) You should try restarting it, maby that will solve the problem.
2) If that does not happen, then go to a computer specialist, there maby is something wrong with your Display.
Jan 10, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
E640 REBOOT
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
Dec 22, 2011 | E-Machines W Computers & Internet
Screen is blank. When turning the power button off and then back on the screen will eluminate correctly but goes blank again after a second.
Have to try a defferent monitor to diagonais a problem but if its showing all your booting process after switching on nothing wrong with your monitor,but if keeps on restarting itself after boot up process ,I'd say that your system error corrupted. Need to reload your sytem.
Sep 03, 2011 | LG 22" FLATRON LCD Monitor
I disabled the network but now I get a blank screen I was getting
It sounds like the computer might be wanting to go a PXE Boot ...
sdef_definition.gif - Preboot Execution Environment (PXE) refers to various methods of getting an IBM-compatible computer, typically running Windows, to boot up without the need for a hard drive or boot diskette. The methods evolved from the era before computers had internal disk drives.
PXE usually involves booting a computer from firmware -- data contained on a read-only-memory (ROM) or programmable read-only-memory (PROM) chip
* Could something wrong in your computer SETUP. Go in Setup (usually f1 or some key right after turning the computer on) and check that there is not a PXE boot from Network or something like that enabled. Could also mean hard drive has went bad.
Jul 07, 2009 | Computers & Internet
Blank screen when booting up
Why are you trying too boot in SM ?
Feb 23, 2009 | Sony VAIO VGN-FS980 Notebook
Xp boots and hang up on blank screen
Insert the original Windows XP "System Restore" CD-ROM,
and tell your computer to "boot" from it.
Does it boot, and get to a screen that asks you "do you really want to ...", or does it stop at a "blank" screen?
If it "stops", you have a "hardware" problem.
If it "asks", then either:
* your disk-drive has failed, or is about to fail,
* your installed copy of Windows is messed-up, and it cannot complete the "boot" process.
Take your computer to a computer-store, for more trouble-shooting.
Aug 28, 2008 | Computers & Internet
HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
