Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
No picture picture comes on for two seconds then goes black. i can power it off and on again and it does the same thing again. i have replaced the cables and tried a different monitor on the comp.
  • 1 more comment
  • king007 Nov 12, 2007
    Please describe the specifics of your problem below. We'll add
    your post as a comment to justin4449's no picture problem, and notify you when a new solution is offered
  • jeepster Dec 09, 2007
    exact same problem as justin4449's. My solution was to call Dell Tech support and they sent me a new monitor. Old one was 31 months old.
  • Anonymous Oct 01, 2008
    got power , black screen
I have the same problem and have been told this is a failed backlight inverter if you can use a flashlight and still see images on the screen. I can find one online for model 1703 but not the 1704. Still looking for a source for it. Replacing the inverter requires almost total disassembly of the monitor so be sure you want to spend that much on it. Good luck.
Posted on Jan 19, 2008
There is a good chnace your Backlight bulbs need to be replaced.
Posted on Jan 03, 2008
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Monitor screen is black. If I switch it off and on again it'll light for 1 second and then go off. I rebooted and it came on for 1 second each time the powering up screen changed.
The picture board on your monitor is bad, since it goes off after a second and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Regards.
May 17, 2010 | Computers & Internet
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
When i turn the monitor power button on monitor come on for about 3 seconds then screen goes black but power button is still lit. tryed old monitor and it works fine
The picture board on your monitor is bad, since it goes black after three seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 22, 2010 | LG W2252TQ Monitor
My picture goes blank
One of two things, the backlight inverter board is going bad (usually has open winding on the transformers), second, the 24vdc power supply section of the main power supply module is bad due to bad filter capacitors.
May 25, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
312 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
