Question about Epson Aculaser C1100 Printer
Error message on epson aculaser c1100, service required C1020?
Replace rom
Posted on Aug 04, 2009
  • hongxldm Aug 04, 2009
    replace rom
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
EPSON ACULASER C1100 When running a given Message Service Req Error E537 Please help me
E537 is the Fuser error check the latch lever of the fuser assy is set incorrectly
Oct 09, 2010 | Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
I've a notice in epson aculaser 1100 lcd (service reg E511)
The E511 error for your Epson Aculaser  in most cases means that its motor has malfunctioned or something is preventing the motor from working properly.
Jan 26, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Dec 20, 2008 | Epson Aculaser C1100 Printer
Service req E527 error
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
Epson aculaser c 1100
What was the service error code It would look something like Service Required E510. This show on the panel and/or in the status monitor
Without this code all we know is your printer has something wrong with it.
Sep 14, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
720 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
