Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
After formatting my hard disc, the system OS (Windows XP) does not detect my sound devices. As my original Motherboard CD is brocken, i don't know how to get the required driver for the Sound Card. Could you please help me fixing the problem!
  • 54 Answers
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
First boot device option not showing in boot menu
There are several things that could cause the problem. There could be no power to the device or no data cable connected (loose cables), the boot record could be corrupted or the device has failed.
If you recently opened the case (desktop), make sure that the 4 pin power cable is fully seated in the device and that the IDE cable is correctly connected to device and the motherboard (at the master cable connection). (Take the device out of the case and check that the jumper is set to Master or Cable Select. This can vary depending on the manufacturer. If you are unsure, please post a comment with the device information.) If you have a laptop, the IDE and power cables are unified at the device (44 pin). The cables can also come loose or damaged. Try replacing the cable or using a different power connection from your power supply.
Try accessing the BIOS and see if the device is listed. (Depending on the motherboard, this can be accessed by pressing ESC, F1, F2 or F10 repeatedly as the computer starts. If you miss the timing, try again.) If the BIOS doesn't list the device, the computer can't see it.
Which device is currently not showing up? If it is your hard disc, get a system recovery, install or upgrade disc for your OS. With a Windows OS, get one that matches the service pack and version (Home or Pro) that is currently installed. Boot to CD (press F12 repeatedly as the computer starts) and select the Repair option. Attempt to repair the Master Boot Record with the BootRec command in the command prompt. Type "bootrec /fixmbr " without the quotes followed by enter. (Other bootrec commands may also be needed. A complete reinstall of the OS might be required if the bootrec repair doesn't work.) Note: bootrec is used with Vista and Win7. XP just uses the fixmbr command directly.
If these steps don't help, you may need to replace the device. If it's your hard disc, you may need to use your system recovery optical disc set and backup to restore your computer. You might be able to salvage the data from the original hard disc by placing the drive in the freezer (protect it from the freezer moisture). However, some of the OS information or the original recovery partition on the disc may not transfer so you need to be prepared to reinstall your OS if you do not have the recovery disc set.
I hope this helps.
(Yes, I've dealt with a corrupted MBR with Win7. Assuming you made a System Repair disc, it's not too bad. If you have an older Windows OS that didn't ship with a Windows CD, find someone with the install CDs.)
May 29, 2012 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Front buttons don't work on CF-19 (MK2) After upgrade from xp sp2 to xp sp3!
From the description, the laptop will only support SP2 the only suggestion I can offer is format the hard drive and reload your original disc to get the front controls back.
Apr 26, 2012 | Panasonic Computers & Internet
How to reformat laptop
  • 1
    If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  • 2
    If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  • 3
    If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  • May 05, 2011 | Computers & Internet
    How do i format it to how it was when i got it
    If you still have the disk for your OS then the process is fairly simple. Insert the disc and reboot the computer. While the computer is booting hold down ESC or possibly F2, F8, or F12. A boot menu should open up before your operating system begins to load and you should pick to boot from CD Drive. When the setup loads, go through the menus until you get to the section of where to install the OS. Delete all the partitions on your computer and then reinstall the OS on the new one. This will delete everything on your laptop and just have a clean copy of your OS.
    If you don't have the original CD you can download and burn this onto a CD and boot it from CD. This will securely wipe your hard drive.
    Apr 25, 2011 | Acer Aspire One PC Notebook
    My Acer Aspire T650 Computer came with Windows XP Home Edition installed on it. However, viruses invested the operating system and I had to do a fresh installation. Because the computer did not come with...
    The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
    Feb 26, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
    How to format my kingston128gb on window xp
    Plug it in the USB, wait to be detected - an icon will appear in the notification area, open My Computer, Right click on it - it's the removable media entry, select format, select NTFS.
    Sep 26, 2010 | Computers & Internet
    Xp is not install
    Best solution is to get and use the original restore discs.
    If using a regular XP disc installation requires specific technical steps to boot from the disc , delete the existing partitions, format and install then download original drivers one at a time.
    Getting the original restore discs would be alot easier than using an XP disc
    hope this helps
    Roety
    Apr 03, 2010 | Computers & Internet
    New ASUS A8V-MX motherboard will not boot to CD or HD with XP
    The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
    Jun 03, 2009 | ASUS K8V-MX Motherboard
    Sound Devices
    Try downloading the drivers from the Compaq website or do a search useing the model number and the word "driver".Reinstalling the drivers and the computer would detect the card.
    Regards
    Godfrey
    May 20, 2009 | Compaq Audio card Sound Card
    HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
