Question about Electric Stanley Tre500 Staple Gun / Sharpshooter
TRE 500 Staples don't go in deep enough.
So far no answer to this problem. Is it an adjustment on the dial?
  • 187 Answers
Dial controls depth. Set it to "+." Watch out setting isn't accidently changed during use. Tre500 isn't powerful enough for hardwoods, etc.
Posted on Nov 13, 2009
  • wire12me Nov 14, 2009
    Margie, this tool has very little power behind it. Try using the smallest diameter nail/staple you can. Make sure that the dial on top is turned up all the way, and recheck it constantly b/c it moves as you handle the tool. Keep the nose as flush to surface as you can.
Can't get the tension set right. bumps on top
Means thread is way too loose. Up tension dial number until the thread just skims the surface of the fabric.
Feb 16, 2015 | Sewing Machines
Frigidaire stove burner not working
There is an allen head adjustment screw under the burner so you can adjust your burner fuel. It is adjusted too far and is going back to the simmer level. Just find the right size allen wrench and turn it to the lefft and adjust it to the proper setting.
Mar 10, 2014 | Kitchen Ranges
How do you set the day and date on the boyfriend watch
the watch should have a dial on the side, you can control time as well as day and date by pulling on the dial, depending an how far it it pull
Jun 05, 2013 | R.J. Graziano Boyfriend" Bracelet Watch
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a fuse box diagram for a 1995 Honda Prelude.
The manual indicates Fuse 11 (10A) interior fuse box, INSTRUMENT PANEL LIGHTS.
Also, the is a dimmer for them:
The dial on the dashboard to the left of the instrument panel controls the brightness of the instrument panel lights. Turn the dial to adjust the brightness.
To reduce glare at night, the fuel and temperature gauges dim when you turn on the parking lights or headlights. You then adjust their brightness when you adjust the instrument panel brightness. Turn the dial up as far as it will go to return the fuel and temperature gauges to their daytime brightness.
You can try the following URL for a copy of your manual (which includes fuse box diagrams). You won't be able to save the whole thing (except by sections), but you can print copies of whatever sections are important to you. You'll need Adobe reader (free from Adobe) to read the manual.
https://techinfo.honda.com/rjanisis/pubs/om/PR9595/PR9595MAINIDX.pdf
Hope this helps you.
Nov 29, 2009 | 1997 Honda Civic
Just bought a used 1995 Honda Prelude and the Tach and speedometer work along with the clock but I can't see any other gauges. (Gas, oil, temp and whatever else might be there. What is the problem?
Since you just bought the car, I thought that you might not be aware of the instrument lighting control. I apologize if you know this:
Hope it's that simple.
Nov 25, 2009 | 1995 Honda Prelude
Back lights are dim on speedometer, odometer
You probably checked this, but sometimes we forget.
The dial on the dashboard to the left of the instrument panel controls the brightness of the instrument panel lights. Turn the dial to adjust the brightness. Also, to reduce glare at night, the fuel and temperature gauges dim when you turn on the parking lights or headlights. You then adjust their brightness when you adjust the instrument panel brightness.
I hope helps and it's that simple for you.
Nov 03, 2009 | 1996 Honda Prelude
Combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Sep 11, 2009 | Water Heaters
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I would pack it and send it to GE for repair replacement as defective
Mar 23, 2017 | GE Spacemaker 26976 Cordless Phone
How do I set 1 touch dialing?
It's pretty much phone system dependent on the one touch, but PROG F button, 9+number STORE usually works.
As far as the calling into IVR systems, you may have to press # to send touch tones after you dial a number, or adjust the tone length in programming. Of course not all systems let you change DTMF times, but that's another thread :-)
Carl
Jul 02, 2008 | Panasonic KX-T7731 Corded Phone
Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
954 people viewed this question
Top Electric Tools & Hardware - Others Experts
Jim London
Jim London
Don Eagan
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
