Question about Samsung ML 1450 Laser Printer
Red Error Light on Samsung ML-1450 printer.
I have owned a Samsung ML-1450 for some time. It has never caused me any trouble. However, it needed a new print cartridge (which was replaced).
Now that I turn on the printer, I get a red error light just after a brief green data light. Cancel does not reset or clear the problem, and the printer does not cycle or make any sound once it is turned on.
There is no paper jam, and the doors are all securely shut.
flopez
  • 161 Answers
SOURCE: Samsung ML-1710P Printer Problem
Most probably you took one of the paper sensors out of place. Any printer technician can happily put it back.
Posted on Sep 22, 2007
rigan86
  • 13 Answers
SOURCE: Red light Samsung ml 2010
I had the same problem and I finally solve it!
I simply took out the fuse and put it again in the cartridge, i don't know why, but it works
Riccardo
Posted on May 02, 2008
  • 4 Answers
SOURCE: Samsung ML-2250 red light
Check the paper tray. There's a latch along the lower left edge that's supposed to let the paper pop up when the tray is inserted so it can feed. If the tray looks OK, check the paper path again and look for a torn off piece of something in there. All it takes is one little piece of paper jammed in there to make the light come on. Use a flashlight and try blowing some air through it with the tray out, back door open and cartridge removed.
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: hellow!!!! everyone!!!!!!!
I have found that when this happens the cartridge is not aligning with the micro switch and so take it back out and as straight as you can push it in until it is locked and try again. It will stay red a bit before trying to reset. Even if you turn the power off it will sometimes take about 15 seconds to attempt to start.
I have found when this happens sometimes 5 attempts will get it to work. Easy to replace the cartridge as it is NOT the printer but the cartridge in most cases.
Streak www.streak.asia
Posted on May 11, 2009
SOURCE: On Line / Error light red and printer can't work on ML 2010
Derek Kwaku Asamoah box mc 279 Takoradi. Please am using your product "samsung ml-2250 printer" and the problem is that the online/erro light is on. thank you for your co-operation and i hope to hear from you soon.
Posted on Jul 02, 2009
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
Print distorted and solid toner column with Samsung ML 1450
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Error light is red, and nothing prints
i think your paper sensor is damaged, replace it
red light show : when paper is not present or toner is not accepted, or door open
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 22, 2009 | Samsung ML 1710 Laser Printer
Jun 08, 2009 | Samsung ML 2010 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
I have lost the software/driver of my samsung printer ml 1450,now i can not install online.
Here is the link for the windows driver for your printer.  http://printers.free-driver-download.com/Samsung/14072/Samsung-ML-1450-Printer-Driver-Windows.html
If this helped you please rate, thanks!
Jan 13, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-1450 "Time out" error
I would try to reinstall the drivers for this printer and make sure it is your default or selected printer. It sounds like the drivers were changed or corrupt. Any new software install may of done this. Also try to let the printer be unpluged from power for 24 hours.
Jan 08, 2009 | Samsung ML-1450 (Open Box) Printer
Samsung ml 1450 printing problem
either paper is stuck in it somwhere, your carts are **** or the fuser is worn out.
Dec 17, 2008 | Samsung ML 1450 Laser Printer
HELP!!! Samsung ML 1640
http://www.fixyourownprinter.com/forums/printer/59558
Oct 13, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 1450 Laser Printer Logo
403 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
