Question about Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook
Macbook hanging on startup
Relatively recently, I was using the Macbook and it just suddenlyfroze. This has never happened before. The mouse froze, no spinningbeach ball, just a frozen screen.
I finally fixed that issue after re-formatting the hard drive a couple times, and installing Mac OS X 10.5 from a retail disc.
The laptop was fine for a while, but the last time I tried to turn onthe laptop, it just hangs on the gray Apple logo screen with the''spinning wheel'' thing.
Here's what I've tried:
  • Repair the hard drive using disk utility on my 10.5 retail disc. No problems detected with that.
  • Reformat the hard drive. Completed okay.
  • Reinstall Mac OS X 10.5 from retail disc. Tried this many times and still hanging at random points when booting.
  • Install Mac OS X 10.4 from discs included with Macbook. No luck here either.
  • PMU and NV RAM reset. Zero...
I can't think of anything else to do at the moment. This is driving mecrazy. I can't shell out $1000 for a new Macbook and I don't feel likeI should since this one has never worked great.
  • sarah_lane Jun 04, 2009
    I've reset the PRAM with no luck. I' ve also tried using Drive Genius 2 to rebuild the drive, then reinstalling Mac 10.5 from a retail disc. It's still hanging on the start-up screen. When I've reinstalled Mac OS X 10.5, it appears to install okay which makes me assume that it isn't a problem with the hard drive. The memory was upgraded once from the original 2x256mb to 1.25GB. Maybe the memory has gone bad? I could try swapping it out with the old memory. Thanks for your suggestions.
    In case you didn't read, I already did reformat the hard drive -- several times. I've also tried installing Mac OS X from fresh retail disc's after doing so. No luck with that. I'm having a feeling this is a hardware problem, not software.
    President:
  • 1,197 Answers
Hello  - have you tried booting with the OS 9.0 CD? If not, take a look at this link for instructions from Apple's support site on how to boot into Classic from the CD.
If you can boot into Classic, see if your hard drive is mounted (if it shows on the desktop.) If so - try running Disk First Aid's Repair option.
Stick in the tiger or leopard DVD and press C after it chimes to boot up from the cd, that should tell you if it is the hard drive or not.
IF THAT DOESNT HELP.....
Okay, shut down the Mac (hold down power key)
Restart whilst holding down Command-S
The screen should turn black and load some text
At the prompt type
fsck -fy and press Return
Hopefully some repairs will be performed.
At the prompt type
reboot and press Return
IF THAT DOESNT HELP
You can always start up in verbose mode (hold down "apple" and "v"). This way you can see your computer loading. If it stops reporting, and the HDD spins down, then you may have some corrupted filesystems or something.
TRY Resetting the System Management Controller (SMC) http://support.apple.com/kb/HT1411
IF ALL ELSE FAILS UR LAST OPTION IS TO try a Archive and Install. It's helpful if you have an external drive, FireWire especially. If you have a FireWire cable and another Mac, you could also try booting your MacBook to your other Mac. When you boot up hold the T key and your Mac should boot up to a screensaver with a moving FireWire logo. Make sure you have the FireWire cord running from your MacBook to your other Mac and then the MacBook should be shown as a drive on your other Mac. You can then copy files and even try to sort out the problem there. You can run Disk Utility on the MacBook too. Refer to this page for more information.
THANK YOU GOOD LUCK
Posted on Jun 05, 2009
    Sergeant:
    Champion:
  • 214 Answers
This problem happens generally because of virus(trojan). And this virus was inactive for mac again just format your drive and install the os.......do not install anything else except os now, soon installing the os just install the latest antivirus software... i will recommend you to use "Quick heal anti virus" now scan the whole system. you will found a malware..... deleat it.        now onward you can install any thing and you can use your laptop as before
Posted on Jun 04, 2009
    Brigadier General:
  • 3,917 Answers
I see you have done quite a few basic troubleshooting steps. Its good. Before concluding that there might be a problem with the RAM I would suggest you to do the following as well:
Hold down Option while booting up, which will force the MacBook to look for bootable drives; you should see Mac OS X appear on a gray screen with an arrow underneath it-click the arrow to proceed loading Mac OS X.
or
Well you could try right clicking on the boot camp task bar icon in windows and selecting “reboot in OS X” or if that doesnt work, you’ll ether have to reinstall OS X or, if you have a time machine backup of OS X, restore it from that.
Also
Before you go reinstalling all of OSX, try resetting your P-RAM. As soon as you press the power button, hold down Command+Option+P+R, until you hear the startup chime 3 times. Then release the keys and see if it boots up.
If this doesn’t work and you have to resort to reinstalling OSX, you should be able to select the option during install so that it will keep your accounts and user files intact. If it doesn’t offer this, you can do an “Archive & Install”, then drag over the files you wish to keep from the old system folder it creates.
If you want more info on this check out the mac support website on OSX installation options.
Else
Can you boot from the OS X installer disc by holding the C key down?
If you can, run the Disk Repair under the Utility menu (after you get past the Language screen.
If this doesn't fix it, or you can't boot from that disc, call Apple for service.
bobw
http://www.macosx.com
Thank You for contacting Fixya.
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
GE 97986 mouse and Macbook Pro
try a hp mouse it worked for me
May 25, 2012 | GE ho97986 Mouse
At the startup my presario v3000 gives continues beeps (loudly) when press the enter key its lorded xp, but some icons in the desktop is bliking, during this time left mouse button not respond, using key...
Does that still happen when the mouse is unplugged? If so, you'll need to replace your defective mouse.
Otherwise if you recently installed something and now this is happening, try to uninstall it.
Apr 17, 2011 | Computers & Internet
MacBook Air froze while "ON"
Yes. Holding down the power button for 10 seconds will power off the laptop.
Mar 30, 2011 | Apple MacBook Air
My Macbook froze and now won't start up
You need to perform "Archive & Install" of Mac OS.
Oct 05, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Have used for months successfully. Suddenly it hangs on strtup and can't be used.
It could be that after you installed 10.5.7, that it caused some incapatibility.  You might want to try to revert back to 10.5.6 to see if that works.
May 20, 2009 | Macromedia Dreamweaver MX 2004
Emachine desktop is hanging at the intial startup screen
Most probably the keyboard has konked out. Simply try the same with a working keyboard & mouse, 'cos it seems to get stuck during POST(power on self test) due to one or more components malfunctioning. If you had removed the PS2 jacks recently, check for bent pins too.................sodeep
May 16, 2009 | E-Machines eMachines Desktop PC
Is there a hold button on aspire one the laptop?
Try holding down the "Fn" and press the "F7" key. This should startup the touchpad Mouse again...
Feb 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Nov 06, 2008 | Gateway Computers & Internet
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
48 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
