Sharp R-510HW Microwave Oven Logo
Posted on Jun 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model # R930AK Looking for a way to change the light bulb. Not sure how to get to the bulb.
William Miller
Level 3:
  • Sharp Master 9,179 Answers
  • Posted on Jun 06, 2009
William Miller
Sharp Master
Level 3:
Answers
9179
Questions
Helped
4480717
Points
21747
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Trying to change the light bulb on my kenmore microwave model #72162369200. How do you get to it?
Not sure on your model but my Kenmore Microwave has the bulb up above the plastic ceiling inside.
It's semi-rigid so you flex it slightly and the tangs come free and it comes down.
I have a Sharp Carousel convection microwave, model#R930AK-F. Built in NOV< 2005. The fan runs, the tray will not rotate, and it does not heat food.
microwave's have fuses in them. try and replaceing them before you call the repair man.check on the web. for locations of fuses,hope this helps
8helpful
2answers
Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
Microwave, convection R930AK turntable will not turn and microwave will not cook. inside light works
That would be a defective secondary (lower) door switch or possibly the door switch mount is loose or misaligned.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
Blown fuse
These items are not expensive
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757868&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757867&PPStack=1
Insert your model ( sharp R930AK ) at search tab of link below and select "thermostat/Thermal fuse " at PART TYPE to see parts availability
2helpful
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Sharp MICROWAVE CONVECTION R-8465
I fixed it by reading how to fix another model. What you do is take the cover off, the bulb is on top. Make sure that you unplug it before starting.
2helpful
Ummmm I feel stupid
The manual is on the Emerson site at:
http://www.emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
But it doesn't seem to mention a way for you to change the lamp.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
