Question about Saeco Incanto Classic Espresso Machine
Coffee cold The Saeco Incanto no longers produces hot coffee.  Machine was inadvertently left on for a week.  Don't know if that woudl be the cause.  But re-starting and doing all that the book suggests does not solve problem. It DOES produce steam with the wand.
  • ryochelson Jun 04, 2009
    Thanks very much for that. Do you know how I re-start the boiler thermostat, or where I find it to remove it?
    President:
  • 1,618 Answers
Your model has 2 boilers, it is possible that the coffee boiler thermostats have tripped, or the element is damaged.
Posted on Jun 04, 2009
  • Ernest R
    Ernest R Jun 05, 2009
    You will have to remove the top panel of the machine to access the boiler, when you find it you will see a small brown cylinder with 2 wires going to it and a small push in switch in the middle, there might be 2 on them on th boiler.
Saeco incanto del luxe coffee machine dumps coffee into waste drawer
Your brew unit may be set in the wrong position inside the machine if someone has had it out to clean or try to fix. The unit has two positions open and neutral when putting back into the machine it should be neutral. This is something I would try first. Now if it is in the open position you will need to reset it. Resetting is better explained on video so I have put a link for a Youtube video. This guy is great and guides you through step by step. Hope this works for you good luck. Please post and let me know.
Cheers
How to Remove Stuck Brew Unit Q
Feb 06, 2015 | Saeco Incanto Classic Espresso Machine
Prime indicator always flashing after 3 seconds (saeco incanto classic)
sounds like thermostats...are shot..will need a model number to help you out.
Mar 10, 2008 | Saeco Incanto Coffee Maker
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
How do I pre brew
I got one of these for xmas, and I was able to program the pre-brew option.
First, turn off the machine.
On the front of the machine, there is series of 5 buttons. (From left to right, they are: Small Coffee, Large Coffee, Pre-ground Coffee, Hot water and Descaling.)
While holding down the 1st (Small coffee) and 4th (Hot water) buttons, turn on the power.
Wait 3-5 seconds before releasing these two buttons. You machine is now ready for programming.
Below the 5 buttons are 4 small lights. If the second light from the left is red, the machine is already programmed to pre-brew. If the light is not red, do the following:
Press the Coffee button (2nd button from the left) once and the second light from the left should glow red. This turns on pre-brewing. (Pressing the Coffee button again will turn off both the light and the pre-brew option.)
Now turn off the power for at least 5 seconds. The next time you turn the machine on, it should pre-brew the coffee.
The process worked great for me the first time, but when I wanted to program the machine to not pre-brew, I had to go through this process a couple of times. Not sure why, though. :-)
Kathy
Jan 13, 2009 | Saeco Incanto Classic Espresso Machine
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Cold coffee, machine does not go through warm up cycle
I think its the main element that has a fuse thats need to be reset.
There is 2 kinds of elements on this machine one for the steam and one for the coffe.
On the main element there is 2 automatic fuses that you can reset by just clicking on them.
Jun 28, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto expresso machine is producing thin, watery and cold coffee. I have walked through some troubleshooting with a Saeco rep and no better results. The top warming plate stays hot. Water flows...
It sounds like the heatingellement of the boiler is broken.Pump works. you also , if i am right get no hot water if you try that.
You can get the part on line. which will be cheaper than doing it through saeco
Try this link SAECO PARTS
Placing it is not too hard as long as you work methodical.
Apr 28, 2008 | Saeco Incanto Classic Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
146 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
