Question about WYSE Winterm S30 Network Terminal
S30 input not supported error message
S30 error message input not supported.
  • malt_vinegar May 11, 2010
    When does this error happen, and what triggers it? Simply posting an error message with no environmental details, or situational factors is not going to help us help you with this!!
Pc input mode not supported
Try an adapter to the video input. Allot of places sell them. Best Buy Comp USA Radio Shack. It is VGA but if there os no support that is thle best way.
Check the cable there are a few vatiations.
Mar 24, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
When i switch on my sony cybershot DSC-S30 camera
A letter and number error code of C:13:xx is an indication the recording media (floppy disk or Memory Stick® media) you are using is either not supported for use with the camera, not formatted properly, or is damaged or faulty.
Refer the links:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C356202&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=76702925&stateId=0%200%20180284222
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Oct 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Sigmatel mobile s30
sigmatel s30 how to disconect the headphone conection
Mar 31, 2009 | Cell Phones
Vista Drivers for Sony DSC-S30 Camera
No updates for Vista available for DSC-S30
You can see details on Sony Support, please check bottom of page.
As suggestion, You can use "memory card reader" to transfer pictures in PC.
Feb 23, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
Cannot log onto network - get message "waiting for network services"
On the DNS-server (Active Directory) you have to generate spesific IP-address for each thin clients MAC-address.
Jun 02, 2008 | WYSE Winterm S30 Network Terminal
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
Reflashing wyse s30 unit
It probably has to do with the version of CE client that is installed on the Thin Client. I have run into this problem before. The same Wyse clients can have different versions of CE installed. If the versions are the same then contact WYSE tech support to find what the error code relate to. BPCS
Dec 08, 2007 | WYSE Winterm S30 Network Terminal
WYSE Winterm S30 Network Terminal Logo
518 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
