Question about Texas Instruments TI-85 Calculator
Turned up display, but not dark enough to see display
I used the great advice provided by another user. But the screen is still too light to read. Does this mean that I need to update and buy another one?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
No. You can adjust the contrast by pressing and releasing the 2ND key, then pressing and holding the Up key to increase the contrast. Obviously, you can decrease the contrast by using the Down key instead.
Posted on Jan 23, 2010
Fine tuning the contrast & darkness
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
May 29, 2014 | Envision Peripherals 19" envision g917w1...
Samsung np x120 no backlight
The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck!
CreativeTECH
Jun 04, 2011 | Computers & Internet
My laptop screen is dark but I can still see something but very vaguely
The screen displays is dark/ dim because there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both. But most likely it is the CCFL (Lamp). Its life is limited and depending upon how long it has been in use, you can have a better idea - if its the CCFL or Inverter.
(Rest assure that your system is ok and you can check it by connecting you laptop with some external display, which would work fine)
So, my advice is that you get it properly checked by any professional for replacement of CCFL.
CreativeTECH
Feb 22, 2011 | ASUS F3F Notebook
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
Averatec N1000 dark screen
yes what u need to do is that connect the external monitor with the laptop and if works fine with the external monitor then what u can try is that uninstall and reinstall the video driver and ten restart ur comuter and still if that doesnt work then replace the lcd screen...
Jan 25, 2009 | Averatec 1000 Notebook
Blank view finder fe-190
try switching your camera on in a dark room (do it at night with the curtains closed and the lights off).
if the screen lights up (should still be black or a very dark green),
then the lens or light sensors might not be functioning correctly.
if the screen stays conpletely black, then the actual screen might be damaged.
note- you might need to let your eyes adjust to the darkness before you switch your camera on.
May 22, 2008 | Olympus FE-190 Digital Camera
Screen went dark
this hapeened due to the fialure of a thn light placed in the screen . it cn be replaced but it cost more. its a flurocent like tube placed in the screen provided in the top of screen
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
Display light is dark
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
Sep 04, 2007 | Shinco SDP-1750 Portable DVD Player
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
Jan 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Texas Instruments TI-85 Calculator Logo
91 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
