Question about Garden
I have a 42 in. 12.5 hp lawn tractor. It stopped running. I have replaced the battery, alternator, and had the started checked. Now, when I turn the key, all there is, is a click. I have been told the motor may be locked up and that the screen at the top of the motor should turn freely when not in operation. I can not get this tractor to do anything. I get 1 click when I turn the key.
  • rjivaro May 11, 2010
    Is it a click like the solenoid activating or a click like the starter trying to spin and stopping? Some B&S engines use a plastic starter gear and the assembly wears out and needs replacement. Requires flywheel removal.
Place you hand on the top of the engine (the screen looking round'ish thing) and try to physically turn the motor. If it turns, it's not seized - just for grins and giggles, try to crank it now - this simple turn of the engine corrected a problem on my almost 20 year old B&S and my Father-in-laws <1 year old B&S - both are 12.5 HP.
I hope this helps...
Posted on Sep 09, 2009
  • 148 Answers
Have you checked the starter motor? It sounds like it is bad. You might be able to remove the blower housing cover and physically turn the starter teeth and then try to start (after putting the cover back on). If it tries to start then you have a bad starter (dead spot on the winding). Just replace the starter and you should be good.
Posted on Jun 07, 2009
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My 16 hp b&s simplicity lawn tractor disengages the PTO while cutting the lawn on it's own. Is this alternator issue??
could be either
the voltage regulator will have to be checked for correct out put to run the PTO
It could also be a problem PTO unit that is drawing more current than the alternator can put out
have the system checked out by an accredited mower shop that has an electrician with experience
Jan 08, 2018 | Garden
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
21 hp electric start Craftsman lawn tractor, B&...
Have your mechanic set your intake/exhaust valves at .004 when piston is 1/4 inch past top dead center on compression stroke.
May 19, 2010 | Garden
My LT 2000 lawn tractor starts to turn over but turn once than stops. What is wrong?
Dead battery ... replace it ... at best, you will only get 2 years out of this size battery.
Mar 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
20 HP Craftsman lawn tractor starts easily, but only runs
This is classic dirty gas filter ... I dont say that is all it could be ... but is it classic dirty filter. You might have something in the tank that is blocking gas getting out of the tank.
check it out ...
Oct 20, 2009 | Garden
Craftsamen 18.5 hp battery keeps draining
Either the battery is not being recharged when the engine is running or there is a current drain when stopped. If you are not knowledgeable about electrical tests you can check for current drain by disconnecting the battery negative cable when not running. If the battery stays charged then you need to find the current drain. To check for no charge when running, turn on the headlights with the key on but engine stopped. Start the engine and see if they become somewhat brighter. If brighter, the charging system works. If not, there is a problem in the charging system which needs to be confirmed with a voltmeter.
Jun 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
277 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
