Cold water trickles out. It is somewhat better on warm or hot.
  • 10,515 Answers
There might be many reasons. Let me list all if them so that it would be of great help.
1. Turn the water off and disconnect the hose from the washing machine. Inside the hose connection at the washing machine are small screens. they need to be pulled out with a pick or tweezers (be careful not to damage them) and cleaned. Sediment and water deposits settle there and prevent the flow of the water.
2. Here are some little screens in the ends of your hoses that may be clogged.
3. Have you tried checking the water filter trap screens on the back of the machine where the hoses are connected? Sometimes they get clogged with hard water deposits.
4. It was a part called the water inlet valve, where the hoses connect to the washing machine. It was a $15-20 part. Write down the model # of your washer and go to an appliance parts store. I figured this out by going towww.repairclinic.com.
5. Pull the hose off of the washer, the cold water hose, and removed the screen that goes into the washer. It dmight not look that dirty, but clean it anyway. That would fix this.
6. Behind the machine, right where the hose meets the washing machine line, there is a filter. It's a tiny wire filter, take it out whenever I think the water flow is slowing down, and I clean it. He puts it back in and it's as good as new.
7. Check the screen at the end of the hose, to make sure it wasn't clogged. Unfortunately, it turned out to be a switch in the machine, which regulates the incoming hot and cod water. The switch cost $25 (4 years ago) + labor for a total of $80.
Any further help, let me know.
Thanks for using "Fixya".
Do rate the solution as "Fixya' if 100% satisfied.
Posted on Jun 04, 2009
Just had my Kenmore delivered yesterday and the water trickles in! Initially, when I moved it to warm it did come out normally, but then it also slowed to a trickle. Same if I move it to rinse. I called...
There is a wire screen filter in the water hose where it connects to the water supply. It's probably clogged with sediment from the water supply. It usually happens with the cold water only so try hot water and see if it's better.
Feb 05, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
Sorry to read about your problem, I hope this helps you out.
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
The cold water comes out on a trickle. the warm & hot settings come out normal. nothing is caught in the line.
check the screens for dirt in the end of the fill hoses and the water inlet valve on the machine. you may need to try replacing the water inlet valve.
Oct 24, 2009 | Washing Machines
Cold water trickles
Spring in water valve is weak . Replace water valve .
Jul 06, 2009 | Kenmore 22422 Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Kenmore 90 series washer no hot water
CHeck to see if the screens in the water valve are plugged. If not the hot water side of the valve went out. Replace the water valve and it will fix both the hot and cold problem.
Nov 18, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
