Question about Keystone Microsoft Windows Server 2003 Microsoft Certified Systems Engineer (MCSE): Core Four Instructor-base... for PC
Configuer additional domain - Keystone Microsoft Windows Server 2003 Microsoft Certified Systems Engineer (MCSE): Core Four Instructor-base... for PC
  • Douglessd
    Douglessd May 11, 2010
    Not sure what you want to do here. You have a Windows 2003 Domain and you want to configure another one? As far as I know you can't run more than on domain on the same hardware unless you are using virtual machines. So you just get a new machine and during the install process you select the option to start a new domain. Some of this stuff is a little complex but Microsoft have great articles that describe the step by step process of creating and managing multiple domains. Do some searching on Microsoft's web site.
Change of address
You can not change the address of a website, you can only assign an additional domain to the location of the site.
Either purchase a domain or take a free one from hoster that provide subdomains.
Then connect that domain to your website.
Mar 20, 2011 | Emerson MS3100 3-Disc CD Changer
Tip
How to Reset AD Password for Windows Server 2000, 2003 and 2008?
Have you ever forgotten Active Directory (AD) password? Do you know how to reset AD password? Is there any Windows password reset software to do AD password reset? If not, what to do to reset AD password? Before answering these questions and do AD password reset, you need to what is active directory, Windows domain and domain controller.
What is Active Directory?Active Directory is used by system administrators to store information about users, assign security policies, and deploy software. It was released first with Windows 2000 Server edition and refined further in Windows Server 2008 and Windows Server 2008 R2 and was renamed Active Directory Domain Services. AD components include such domains, domain controllers, trust relationships, forests, organizational units, etc. What is a domain controller?
According to Wiki, a domain controller is a server that responds to security authentication requests (logging in, checking permissions, etc.) within the Windows Server domain. The domain controllers in your network are the centerpiece of your Active Directory service. It stores user account information, authenticates users and enforces security policy for a Windows domain. When you install Windows Server on a computer, you can choose to configure a specific server role for that computer. When you want to create a new domain, or an additional domain controller in an existing domain, you configure the server with the role of domain controller by installing AD DS.
What is a Domain?A domain is a concept introduced in Windows NT whereby a user may be granted access to a number of computer resources with the use of a single username and password combination.
The domain concept not only allows a user to have access to resources that may be on different servers, but it also allows one domain to be given access to another domain in a trust relationship. In this arrangement, the user need only log in to the first domain to also have access to the second domain's resources as well.
So it is hard to say if there any windows password recovery software can reset AD password. Windows password recovery software like Windows Password Unlocker Enterprise can allow you to reset domain administrator password on Active directory for Windows server 2000/2003/2008.
Steps to reset domain administrator password
  • Step 1: Download and install Windows Password Unlocker Enterprise in any available computer.
  • Step 2: Run the software and insert a USB flash drive to computer.
  • Step 3: Select Domain Administrator and target USB drive, and then click the Burn button to start burning an ISO image file to the USB flash drive.
  • Step 4: Click ok when burning process is completed.
  • Step 5: Insert the burned USB flash drive to your locked computer and set the computer to boot from USB.
  • Step 6: Choose the way to reset AD password.
  • 2 options for you to reset domain password
  • Option 1: Reset the default domain administrator password to Pa123456
  • Option 2: Reset AD password by creating a specified domain administrator account.
  • Step 7: Click YES to continue and click Ok when the domain password has been successfully reset.
Now you can log on your domain with the user name of administrator and password of 'Pa123456' if you select option 1. If you select option 2, you can log on domain with the username of 'passkiller' and password of 'Pa123456'.
on Oct 13, 2010 | Computers & Internet
BDC for Windows Server 2003
Windows 2003 does not use the PDC/BDC format like the old NT did. They are all just considered DC's now.
Just run dcpromo on the new domain controler and select the option "additional dc to an existing domain". Once that is done, if you are using Active Directory, it will sync up with the other DC.
Jan 23, 2010 | Microsoft Windows Server 2003 Standard...
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
Domain error when try to run downloaded program
Not enough info. ex: ans(100) is a domain error b/c 1-99.
email raklein62@yahoo.com for additional help. Could be a lot of reasons. I be glad to work through problem w/ you.
Jun 15, 2009 | Texas Instruments TI-89 Calculator
How to configure additional domain controller in win 2003
execute dcpromo to convert a win2003 to a domain controller.
Global catalog is not replicated by default to the new promoted 2003 domain controller.
Feb 17, 2009 | Keystone Microsoft Windows Server 2003...
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
Offline method to convert Additionan DC into Primary DC
go to the ntdsutil in the additional domain controller
and seize all the roles from the existing domain controller
make the additional DC to be a Primary DC
and dont forget to transfer the global catalog
Dec 26, 2007 | Microsoft Windows Server Standard 2003 for...
Why can't I access my ISP's resources, such as their mail and news servers on my RO318?
If the servers have simple names like 'mail' or 'news', the problem may be that the ISP's domain suffix is not being added to these names before DNS lookup. Add your ISP's domain suffix as Domain Name in the RO318's System menu. In addition, the ISP may be looking for a particular host name for your account, in which case you should enter the host name as the System Name in the RO318's System menu. Example: Consider the following account with the ISP "earthlink.net". 1. Host Name: C-223344-A 2. Domain Name: www.earthlink.net Mail Server mail Although the ISP lists the name of their mail server as 'mail', the fully expanded name is actually: mail.earthlink.net If the ISP automatically provides the domain suffix to your router, the router will append the domain suffix to DNS requests. If not, you can try one of these methods: 1. In each application (such as mail client or news reader), list the fully expanded server name, 2. Manually configure DNS parameters in the network settings of each of your PCs, and enter the domain suffix manually.
Feb 19, 2006 | NetGear RO318 Router
Keystone Microsoft Windows Server 2003 Microsoft Certified Systems Engineer (MCSE): Core Four Instructor-base... for PC Logo
23 people viewed this question
Top Keystone Computers & Internet Experts
Tony
Fred Block
Fred Block
OJO Emmanuel Ayodele
Are you a Keystone Computer and Internet Expert? Answer questions, earn points and help others
