Question about Amana HDC18 Microwave Oven
We own an Amana HDC18 commercial microwave. Lately, it has begun sparking intermittently between the door and the floor. There looks to be a thin spot in the coating on the floor right at the bend on the edge near the door opening. It doesn't spark everytime, but it is unnerving. Any ideas? Can the thin spot be repaired?
  • Amana Master
  • 9,085 Answers
The gasket holding the ceramic floor plate may be damaged. If so, it will need to be replaced, or clean the area thoroughly and apply caulk.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jun 06, 2009
Amana RS10D Not heating up . Fuse,2 thermal cut out, door switch, all ok. board/ magnetron/ transformer dead? Pls help. Don't want to discard 5 units...all same problem...Thanks
I regularly repair Amana commercial microwave ovens.
  • What is the FCC ID number from the tag?
  • What is the Manufacturing number (like P76695, etc.)?
  • Is it making any unusual noises?
  • Is it running quieter or louder than usual?
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 11, 2017 | Amana Microwave Ovens
Clean the filter on an anna microwave oven HDC18
The service manual (here) covers that.
You can order Amana parts from the Pros here.
Jan 15, 2013 | Amana Microwave Ovens Amana HDC18 - C-Max...
Our commercial amana microwave model number rcs 10 mpa 1000 watt is not heating/cooking food. The power, lights, fans , display and everything else works fine. I would like to fix this myself. What part...
can be many problems. a defetive magnetron. worn door switches and its bracket/levers. circuit board issues. oven cavity thermofuse. etc.. good luck.
Aug 03, 2011 | Amana RCS10MP Microwave Oven
Rc17 commercial microwave, display shows door even when door is closed.what can i do to resolve
Possible that the door lock switch is stuck and so is not releasing even after the door has opened. Look inside after disconnection of power to the microwave at the place where the door locks. Tap into the lock to release the switch . If the switch is jammed or damaged it must be taken out and replaced.
Mar 31, 2011 | Amana RC17 Microwave Oven
How do i program the times on this model?
Need to program cooking times. What are the procedures?
Jan 30, 2011 | Amana HDC18 Microwave Oven
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
I have an Amana ARGS7650ww. The igniters will not spark.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 20, 2010 | Microwave Ovens
Spec sheet for the Amana HDC18 and HDC 21. Straight 208 vac 3 wire? Control transformer included or do I have to supply a neutral?
The service manual is at our site here.
Jan 15, 2010 | Amana HDC18 Microwave Oven
F5 error code on amana microwave hdc18
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Next I would check the door switches and mounts: http://www.microwavedisplay.com/safety.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you still have trouble, I would suspect a problem with the controller. We regularly repair these for customers nationwide with our guaranteed $39.95 service.
William E. Miller
prototech@usa.net
Sep 09, 2008 | Amana Microwave Ovens
Amana HDC18 Microwave Oven Logo
353 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
